08-29-2013 04:51 AM - edited 03-07-2019 03:11 PM
I just tried to establish a fiber connection between a c4503 and a c2960x using glc-lh-sm modules on both sides, but with no success.
Link comes up on the c2960x but not on the c4503.
I tried "speed nonegotiate" on both sides: link comes up on both sides, but no data received on both sides.
A connection between a c2960-24LC-S and the c2960X-24PD-L works fine, as does a connection between the c2960-24LC-S and the c4503.
All on the same ports and modules and also different ports an modules per switch.
Any suggestions on why a connection between the c4503 and the c2960X doesn't work?
10-31-2013 10:26 AM
Same problem here
1) 2960X (GLC-SX-MM-C) to Sup2T/6509E/6848 -> 2960X shows up/up, 6509 down/down
2) 2960X (GLC-SX-MM-C) to 2960X (GLC-SX-MMD) -> both ports up CDP Nei shows the switch
3) Upgrade Software from EX1 to EX3 -> same behaviour
Switch#show version | incl EX3
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.0(2)EX3, RELEASE SOFTWARE (fc1)
System image file is "flash:/c2960x-universalk9-mz.150-2.EX3.bin"
* 1 52 WS-C2960X-48FPD-L 15.0(2)EX3 C2960X-UNIVERSALK9-M
Switch#
Switch#show int gi1/0/50 capabilities
GigabitEthernet1/0/50
Model: WS-C2960X-48FPD-L
Type: 1000BaseSX SFP
Speed: 1000
Duplex: full
Trunk encap. type: 802.1Q
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off,on,desired),tx-(none)
Fast Start: yes
QoS scheduling: rx-(not configurable on per port basis),
tx-(4q3t) (3t: Two configurable values and one fixed.)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
SPAN: source/destination
PortSecure: yes
Dot1x: yes
Switch#
Switch#show idprom interface gi1/0/50
General SFP Information
Identifier : 0x03
Connector : 0x07
Transceiver : 0x00 0x00 0x00 0x01 0x20 0x40 0x0C 0x00
Encoding : 0x01
BR_Nominal : 0x0D
Vendor Name : CISCO-PROLABS
Vendor Part Number : GLC-SX-MM-C
Vendor Revision : 0x20 0x20 0x20 0x20
Vendor Serial Number : P1A24111
Didn't open TAC case yet
11-08-2013 12:38 AM
Hi all,
I've got the same problem.
Bug: CSCuj70291
1 gig uplink on WS-C2960X-48LPD-L does not link up with 4306, 4448-GB
Symptom:
Uplink port with glc-sx-mm,glc-lh-sm not coming up between WS-C2960X-48LPD-L and any catalyst 4500 with WS-X4448-GB-SFP and WS-X4306-GB. When speed no negotiate is enabled, link comes up, but no traffic.
This is observed with catalyst 6500 line cards as well.
Conditions:
Workaround:
None
Bug-fix will be release on 18th of Nov.
Regards, Alfred
11-08-2013 05:16 PM
I can't believe this bug!
I can see the 2960 BU is doing a "bang up" job in Quality Control.
11-13-2013 01:00 AM
Same issue here. Link does not come up.
Side A
WS-C4506 (WS-X4306-GB linecard with 1000BaseSX GBIC)
Side B
Cisco Catalyst 2960X-48FPS-L* (GLC-SX-MM SFP)
All GBIC/SFP/Linecard Ports were replaces with no effekt. If we configure "speed nonegotiate" then we can see the LED turns green and link shows connected but traffic counters remain zero.
I can assure you that there are no issues with the cabling or SFP moduels, if we replace the 2960x with a 2960s (same config) the link works like a charm!
It looks like this issue is not fixed in EX3, at least not on the WS-C2960X-48FPS-L plattform!
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 11-Sep-13 02:04 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.0(2r)EX, RELEASE SOFTWAR
E (fc1)
AS.... uptime is 23 hours, 33 minutes
System restarted at 12:33:41 MEST Tue Nov 12 2013
System image file is "flash:c2960x-universalk9-mz.150-2.EX3.bin"
11-13-2013 02:28 AM
Hi all,
bug CSCuj70291
Solution provided with EX4 (for C2960X)
Release date 18.11.2013
Regards, Alfred
11-13-2013 03:27 AM
Correction:
bug CSCuj70291
Solution will be provided with EX4 (for C2960X)
Planned release date 18.11.2013
Regards, Alfred
11-19-2013 02:05 AM
hmm can't find the bug CSCuj70291 in the EX4 release note..
but this at least this one:
Caveats Resolved in Cisco IOS Release 15.0(2)EX4
Gigabit link from WS-C2960X-48FPD-L not coming up when using GLC-SX-MM.
There is no workaround.
11-19-2013 10:46 AM
EX4 fixed it today for me.
A painful bug causing a lot of issues.
My main concern is that i suffered from painful bugs in the last 3-4 implementation of new cisco products.
There was no implementation without a Cisco TAC case
11-20-2013 12:41 AM
Hi all,
exactelly, bug CSCuj74167 in the release notes is a duplicate of bug CSCuj7029.
Regards, Alfred
