Fiber Jumper LC/SC for XFP-10G-MM-SR
I need a Fiber Jumper LC/SC for a XFP-10G-MM-SR, does Cisco sell any?
Any help is much appreciated.
Everyone's tags (1)
VIP Super Bronze
No, Cisco does not sell fiber patch cords.  You can buy you cable here:
http://www.stonewallcable.com/product.asp?dept%5Fid=243&pf%5Fid=FJ%2DSCLC&gclid=CNDejobKpawCFYqA5QodCiaj2w
Hi Reza,
Thanks for your answer.
What about the below Cisco fiber cord, would it work?
15216-LC-SC-5=
Cable assembly, LC/PC-to-SC/UPC, single-mode, 4.0m, 2mm jacket
http://www.cisco.com/en/US/prod/collateral/optical/ps5724/ps2006/ps5320/product_data_sheet09186a00801849e7.html
VIP Super Bronze
Same for this one.  You need to buy your fiber patch cords from a 3rd party vendor like the one I provided you above.
Cisco does not sell fiber or copper patch cord. 5 meter LC to SC patch cords are very common and easy to find
Hi Reza,
I believe the below part code is a fiber patch cord from Cisco, isn't it?
15216-LC-SC-5=
VIP Super Bronze
You are correct.  This is a Cisco part number. But I still think, it is easier to buy it directly from a 3rd party vendor.  A 5 meter  LC to SC SM is around $60.(above link)  You can also pick up the cable at the local electronic stores if you have one close by and you only need a few.
Thanks Reza,
My question is would the fiber patch cord below work for the XFP-10G-MM-SR?
15216-LC-SC-5=
VIP Super Bronze
Are both sides of the connection XFP? if yes you need LC to LC and not LC to SC.
1895
