08-30-2013 10:20 AM - edited 03-07-2019 03:13 PM
I intend to uplink NX5020 2 fiber ports to a NX7000 2 fiber ports running port-channel.
I have created on both sides:
interface port-channel10
switchport mode trunk
description NX7000 (SFP) <--> NX5000 (SFP)
I have configure fiber interfaces like this
interface Ethernet1/1
description description NX7000 (SFP) <--> NX5000 (SFP)
channel-group 10
no shutdown
interface Ethernet1/2
channel-group 10
no shutdown
Is there any specific fiber port on NX5020 to uplink to NX7000?
Rosa
Solved! Go to Solution.
08-30-2013 10:59 AM
Hello Rosa,
There is no specific fiber port in N5K or N7K for configuring as uplink port.
as per the conf pasted , its looks like we have to enable feature lacp and configure the port channel as
channel-group 10 mode active
This schould be done in both the devices (N7K and N5K)
Partha
08-30-2013 12:44 PM
Rosa,
yes , you can use it.
In contrast to a static link aggregation, LACP provides the following advantages:[8]
Partha
08-30-2013 10:59 AM
Hello Rosa,
Partha
08-30-2013 11:18 AM
Ooopss!
NX7000 is running version5.2(7).
By now it has fiber trunk connection with 4 Cisco6509 boxes running fine, feature lacp is disables.
NX5020 is running version 4.0(1a)N2(1).
It is being deployed.
Version 4 does not have any feature.
So what do you suggest - try and see ?
Rosa
08-30-2013 12:09 PM
Rosa,
You can verify the what are the feature available in 4.0(1a)N2(1). using show feature. I believe it will have feature lacp if it supports vpc
If feature lacp not available in N5K, you can give try specifying channel group 10 mode on ( I believe u might have already done it)
Partha
08-30-2013 12:19 PM
Partha as NX7000 has feature lacp disabled can I use "channel group 10 mode on " on both sides ?
Qhat are the benefis of using lacp ?
Rosa
08-30-2013 12:44 PM
Rosa,
Partha
08-30-2013 12:52 PM
Partha lacp is realy great!
What a pity, but must upgrade nx-os.
Rosa
08-31-2013 06:52 AM
It works fine !
