Filtering IP traffic by MAC address
stuartbyma
On Catalyst 3560 switch, I am trying to filter incoming IP traffic by MAC address. I have an interface filter set up to deny packets from a specific host with any destination, but the filter does nothing and still permits packets from this host.
mac access-list extended mac3
deny host 0200.0001.2120 any
Is this even possible? Is there another way I should be implementing this that will work? Thanks for any help!
7 Replies 7
Reza Sharifi
If you are trying to block a specific host, use the IP address to block it.
arunviswanath
I think you should bind the acl to the incoming interface.
or try using it with vlan access maps
cadet alain
as far as i know it won't work this way because mac acls only match non ip traffic.
maybe you should try a MQC approach by classifying with source mac and do a drop policy for that class.
Regards.
Alain.
     You can try configuring MAC Address-Based Traffic blocking with this comand:
             Switch(config)#mac-address-table static mac_address vlan vlan_id drop
       This will block all traffic to or from the configured MAC address in the specified VLAN.
tks for the tip
After some reading, it looks like this should work. But, my switch (3560) and IOS version (12.2-55) doesn't support a class map match destination-address mac command. The only way to match it is through an ACL, which as you said, will not work.
stuartbyma
Thanks for the suggestions everyone. I have already tried binding the MAC ACL to an interface, and to a VLAN, but to no avail. Today I will attempt to try the suggestions by HTH and use a static mac address-table entry to drop specific packets.
