Webcast-Catalyst9k
Find Power Supply Serial Number in a WS-C4006
C45SW001#show version
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-IS-M), Version 12.1(8a)EW1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 20-Feb-02 18:02 by eaarmas
Image text-base: 0x00000000, data-base: 0x00AA30DC
ROM: 12.1(20r)EW1
C45SW001 uptime is 2 years, 18 weeks, 2 days, 3 hours, 39 minutes
System returned to ROM by reload
System restarted at 08:33:38 WET Sun Oct 29 2006
System image file is "bootflash:cat4000-is-mz.121-8a.EW1.bin"
cisco WS-C4006 (MPC8245) processor (revision 7) with 262144K bytes of memory.
Processor board ID FOX062500E5
Last reset from Reload
48 FastEthernet/IEEE 802.3 interface(s)
14 Gigabit Ethernet/IEEE 802.3 interface(s)
467K bytes of non-volatile configuration memory.
C45SW001#show idprom ?
all show all IDPROMs
chassis show IDPROM for chassis
module show IDPROM for module
supervisor show IDPROM for supervisor
C45SW001#
Any ideias ?
Best Regards,
Bruno Petrónio
Purple
Re: Find Power Supply Serial Number in a WS-C4006
Normally you would use show idprom power-supply # . If its not there then its because your code is so out of date , only way then is to manually pull them and get the numbers off the power supplies, otherwise upgrade the code and the command will be there. Just used it to get power supplies replaced from cisco. Looking at your display it says 4006 , is this the chassis with 3 power supplies ? If so I don't think you can get that info from the command line with that chassis as that was normally used with catos supervisors and it wasn't available even on catos supervisors that i remember.
Tks Glen,
That's right, 3 PS slot's, and running IOS.
Thank you anyway.
Best Regards,
Petrónio
434
