Find which port device with IP X.X.X.X is attached to
If I have a device that I know the IP and/or MAC address of, is there an easy way of finding which interface it's attached to?
1 ACCEPTED SOLUTION
Re: Find which port device with IP X.X.X.X is attached to
If you use Network Assistant you can do a layer 2 trace from one ip address to another and it will tell you the interface and port that it is connected to. I do it all the time to track down high traffic users that I get from my sniffers.
Gary
Depending on the switch IOS versions, you can issue either "show mac" or "show mac-address".
If you only know the IP, you can to the default-router of that subnet and find the mac-address off of the arp table.
Once you know the MAC, you can trace it down with:
show mac-address-table | inc xxxx.xxxx.xxxx
This will limit the output to only include that mac-address (the formating is important as well as the case).
If you have a catos system, it is:
show cam xx-xx-xx-xx-xx
--Gavin Budd
you can issue the command traceroute mac mac
means traceroute x.x.x x.x.x on a switch
Gary
272
