03-09-2009 09:40 AM - edited 03-06-2019 04:28 AM
Hi everybody!
Today i put on detective hat and out to trace physical location by ip address.
I was just thinking once, we find the ip address used to send e mail, from that ip address, we can determine the physical location.
For example:
If e mail is sent using isp domain say abc.com, then i believe if we can find that isp, from isp( remember we are detectives therefore have all powers to do so), we can locate who is using this e mail account.
Things a lot harder if some one is using yahoo or hotmail account. Say an e mail, abc@yahoo.com is received , then if we have to find ip address then from ip address we can locate which isp is using this ip block, once the isp is located, we can trace the ip address to computer used to send that email( assuming isp keeps the records of ip addresses assigned).
Is my concept correct?
second thing i want to know, how can we find ip address used to send e mail?
thanks a lot!
Solved! Go to Solution.
03-10-2009 02:34 AM
Hello Sarah,
a mail message keeps inside the history of the travel of the message:
for example in a MS outlook client if you select a message right click on the mouse options you can see something:
see for example a message coming from an Internet network exchange
Microsoft Mail Internet Headers Version 2.0
Received: from relay705.servizi.rai.it ([10.24.1.135]) by VTOCERNEXC708A.ict.corp.rai.it with Microsoft SMTPSVC(6.0.3790.3959);
Wed, 4 Mar 2009 19:18:50 +0100
Received: from zrmteul704.ict.corp.rai.it ([10.24.1.190]) by relay705.servizi.rai.it with Microsoft SMTPSVC(6.0.3790.3959);
Wed, 4 Mar 2009 19:18:35 +0100
Received: from Unknown [x.x.x.x] by zrmteul704.ict.corp.rai.it - SurfControl E-mail Filter (6.0.1); Wed, 04 Mar 2009 19:17:19 +0100
Received: from eolo.mix-it.net ([217.29.77.55])
by relay5.rai.it with ESMTP; 04 Mar 2009 19:17:19 +0100
MailScanner-NULL-Check: 1236794829.28668@XPy29cKYA5pCVo1qXT/rpQ
Received: from eolo.mix-it.net (eolo.mix-it.net [127.0.0.1])
by eolo.mix-it.net (8.12.11.20060308/8.12.11) with ESMTP id n24I78os025766
for <peer.tech.scc-pR0va0r4@eolo.mix-it.net>; Wed, 4 Mar 2009 19:07:08 +0100
Received: (from majordomo@localhost)
by eolo.mix-it.net (8.12.11.20060308/8.12.11/Submit) id n24I78kO025765
for peer.tech.scc-pR0va0r4; Wed, 4 Mar 2009 19:07:08 +0100
by eolo.mix-it.net (8.12.11.20060308/8.12.11) with ESMTP id n24HDr8Y004928
for <peer.tech.scc@mix-it.net>; Wed, 4 Mar 2009 18:13:53 +0100
Received: (from apache@localhost)
by eolo.mix-it.net (8.12.11.20060308/8.12.11/Submit) id n24HDrOx004927;
Date: Wed, 4 Mar 2009 18:13:53 +0100
Message-Id: <200903041713.n24HDrOx004927@eolo.mix-it.net>
Subject: Modifica annuncio da AS12779 (ITGate Network) - network advertise update from AS12779 (ITGate Network)
MIME-Version: 1.0
X-MIX-MailScanner: Found to be clean, Found to be clean
X-MIX-MailScanner-SpamCheck: not spam, SpamAssassin (not cached, score=-3.2,
required 4, autolearn=not spam, ALL_TRUSTED -3.30,
NO_REAL_NAME 0.10), not spam, SpamAssassin (not cached, score=-3.2,
NO_REAL_NAME 0.10)
Sender: owner-peer.tech.scc@eolo.mix-it.net
Precedence: bulk
Reply-To: peer.tech.scc@mix-it.net
X-MIX-MailScanner-Information: Please contact the ISP for more information
X-MIX-MailScanner-From: owner-peer.tech.scc@eolo.mix-it.net
X-SEF-ZeroHour-RefID: fgs=0
X-SEF-7853D99-ADF1-478E-8894-213D316B8FFA: 1
X-SEF-Processed: 6_0_1_111__2009_03_04_19_18_35
Return-Path: owner-peer.tech.scc@eolo.mix-it.net
X-OriginalArrivalTime: 04 Mar 2009 18:18:35.0937 (UTC) FILETIME=[A2398910:01C99CF5]
As you can see there are enough information to trace a message (not back to the sender)
Hope to help
Giuseppe
03-10-2009 06:00 AM
I am sorry sarah.
it just does not work like that.
as have been stated before the information is all contained in the mail itself as the mail "internet" header.
however that is normallly as far as you can go.
since you do not have the legal rights to persue any further you cannot force the ISP to tell you where or who is on that ip and thus cannot say where the physical equipment using that ip address resides. in the case of a company doing it you might get that from the registrator of the ip range they use. (whopis)
so as a general rule, detective hat or not noone will talk to you about who uses what ip but the police might get to know if you report the incident.
03-10-2009 02:34 AM
Hello Sarah,
MIME-Version: 1.0
NO_REAL_NAME 0.10)
Precedence: bulk
Hope to help
Giuseppe
03-10-2009 06:00 AM
I am sorry sarah.
