01-26-2009 01:41 AM - edited 03-06-2019 03:39 AM
Hi. I just wish to ask how do i determine the resources usage in terms of processor and ram utilization of a router during actual operation. Is there an snmp function that would provide this or do i access the router itself and type a command to access this information.
Thanks in advance.
Solved! Go to Solution.
01-26-2009 02:08 AM
use these commands in order to get the router's resource usage: show processes cpu and show processes memory
01-26-2009 02:08 AM
01-26-2009 05:51 AM
Also, on the later IOS versions, there's additional options to the commands that John notes that will provide a simple graph of usage history. For instance, show proc cpu history. (There's one for memory usage too, but I don't recall the syntax off the top of my head.)
