Finding Root Bridge CatOS/CATIOS
dmooreami
Level 3
Level 3
Any easy way to find the root bridge? have 6513, 6509, several 2950's and 2948G's.
I know of the show spantree Summary etc. But I have no idea what mac address being returned goes to what switch.
what is cmd to get the mac of switch with CatOS and CatIOS that is being used to determine the root bridge.
Any links appreciated.
6 Replies 6
Giuseppe Larosa
Hello Doug,
you have to follow the path to the root bridge:
be aware that the root bridge can be different for each vlan if you use PVST+ or rapid PVST or for each instance (if using MST 802.1s)
sh spantree vlan#
provides you these informations
then you move to the next switch following the root port.
if you have CDP enabled this is easy just does
sh cdp n mod/num
where mod/num is the root port.
Repeat the steps until you reach the root bridge.
Hope to help
Giuseppe
What is weird is my "core" switch were everything connects isn't the root bridge. I inherited this network, so time for some fixing.
panning tree mode: RAPID-PVST+
Runtime MAC address reduction: enabled
Configured MAC address reduction: enabled
Root switch for vlans: none.
Global loopguard is disabled on the switch.
Global portfast is disabled on the switch.
BPDU skewing detection disabled for the bridge.
BPDU skewed for vlans: none.
Portfast bpdu-guard enabled for bridge.
Portfast bpdu-filter disabled for bridge.
Uplinkfast disabled for bridge.
Backbonefast disabled for bridge.
L2PDU rate limiter is disabled.
I am sure you can change that once you have identified all the switches MAC and priority ID. You can set the core as the root by changing its VLAN priority ID.
rgds,
yes, the CDP cmd was what I was looking for.
Tshi M
Level 5
Level 5
I believe that "sh hard" will have the MAC address of the switch. Here is an output of one my switch. Some lines are omitted:
cisco WS-C3560-48PS (PowerPC405) processor (revision M0) with 122880K/8184K bytes of memory.
Processor board ID CAT0936Z1QA
Last reset from power-on
2 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:15:62:F4:EE:80
sh span vlan 4
VLAN0004
Spanning tree enabled protocol ieee
Root ID Priority 32772
Address 0015.62f4.ee80
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32772 (priority 32768 sys-id-ext 4)
Aging Time 300
Interface Role Sts Cost Prio.Nbr Type
Fa0/41 Desg FWD 19 128.45 Shr Edge
Fa0/47 Desg FWD 19 128.51 P2p Edge
Po1 Desg FWD 3 128.56 P2p
you can see the MAC address from sho hard and it appears in the sh span vlan 4.
rgds,
For each vlan do a "show spanning tree vlan # for IOS and show spantree for catos . This will give you the root bridge and the root port if the switch is not the root for the vlan , just follow the root port until you find the root for each vlan . For catos you can use "set spantree vlan X root primary to set root on catos box. For IOS use " spantree vlan X root primary " .
