12-01-2006 03:10 AM - edited 03-05-2019 01:07 PM
Hi all, can anyone tell me what the conduit command does on a pix firewall ?
12-01-2006 04:03 AM
Hi Carl, this command was used in earlier versions instead access lists, you can use now both but normally it is used an access list.
See next url about this:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008009402f.shtml
pls, rate the post if helpful
12-01-2006 04:20 AM
so we wouldnt use this anymore then ?
12-01-2006 04:35 AM
Hi, as you can see at the document you can use it if you want, it hasn't dissapear fo compatibility, but if you're going to start a new configuration if better starting using access list.
Regards.
