firewall conduit command
Hi all, can anyone tell me what the conduit command does on a pix firewall ?
Silver
Re: firewall conduit command
Hi Carl, this command was used in earlier versions instead access lists, you can use now both but normally it is used an access list.
See next url about this:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008009402f.shtml
pls, rate the post if helpful
so we wouldnt use this anymore then ?
Silver
Hi, as you can see at the document you can use it if you want, it hasn't dissapear fo compatibility, but if you're going to start a new configuration if better starting using access list.
Regards.
189
