Firewall on 1921 K9 blocking UDP traffic it should be allowing
I have a 1921 K9 with a 4 port 10/100/1000 EHWIC switch.
Interface 0/1 = 192.168.1.0
EHWIC = 192.168.5.0
I have Active Directory setup on the 192.168.1.0 network. When I attempt to join the domain from 192.168.5.0 it joins but I get errors. After some troubleshooting using portqry I have found that the services related to class map DomainTrafficUDP are being reported by portqry as being filtered regardless of policy map settings (currently set to allow) I hope someone can shed some light on this.
Building configuration...
Current configuration : 18833 bytes
! Last configuration change at 11:20:25 NewYork Thu Apr 19 2012 by dave
! NVRAM config last updated at 13:56:45 NewYork Wed Apr 18 2012 by dave
version 15.1
service password-encryption
hostname Bulldog
boot-start-marker
boot system usbflash0:c1900-universalk9-mz.SPA.151-3.T.bin
boot-end-marker
no aaa new-model
clock timezone NewYork -5 0
clock summer-time NewYork date Apr 6 2003 2:00 Oct 26 2003 2:00
no ipv6 cef
no ip source-route
ip cef
ip dhcp excluded-address 192.168.5.1 192.168.5.24
ip dhcp excluded-address 192.168.101.1 192.168.101.10
ip dhcp excluded-address 192.168.100.1 192.168.100.2
ip dhcp excluded-address 192.168.25.1 192.168.25.10
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp excluded-address 192.168.5.1 192.168.5.10
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.1.10 192.168.1.254
ip dhcp pool Noc
   network 192.168.1.0 255.255.255.0
   dns-server 192.168.1.6 192.168.1.3
   default-router 192.168.1.1
ip dhcp pool MGMT
   network 192.168.101.0 255.255.255.240
   default-router 192.168.101.1
ip dhcp pool VDI
   network 192.168.100.0 255.255.255.0
   default-router 192.168.100.1
ip dhcp pool App-Servers
   network 192.168.25.0 255.255.255.240
   default-router 192.168.25.1
ip dhcp pool Ext-Servers
   network 192.168.10.0 255.255.255.240
   default-router 192.168.10.1
ip dhcp pool Int-Server
   network 192.168.5.0 255.255.255.240
   default-router 192.168.5.1
ip name-server 192.168.1.6
ip name-server 192.168.1.3
ip port-map kerberos port udp 88
ip port-map user-ldap port udp 389
ip port-map user-SOAP port tcp 9389
ip port-map user-DFSR port tcp 5722
ip port-map user-WINS port tcp 42
ip port-map user-GlobalCatalog port tcp from 3268 to 3269
ip port-map user-NetBiosNR port tcp 137 description NetBios Name Resolution
ip port-map user-RemoteDesktop port tcp 3389 description MS RDP
ip port-map user-SMB port tcp 445
ip port-map user-RPC port tcp from 49152 to 65535
parameter-map type protocol-info msn-servers
server name messenger.hotmail.com
server name gateway.messenger.hotmail.com
server name webmessenger.msn.com
parameter-map type protocol-info aol-servers
server name login.oscar.aol.com
server name toc.oscar.aol.com
server name oam-d09a.blue.aol.com
parameter-map type protocol-info yahoo-servers
server name scs.msg.yahoo.com
server name scsa.msg.yahoo.com
server name scsb.msg.yahoo.com
server name scsc.msg.yahoo.com
server name scsd.msg.yahoo.com
server name cs16.msg.dcn.yahoo.com
server name cs19.msg.dcn.yahoo.com
server name cs42.msg.dcn.yahoo.com
server name cs53.msg.dcn.yahoo.com
server name cs54.msg.dcn.yahoo.com
server name ads1.vip.scd.yahoo.com
server name radio1.launch.vip.dal.yahoo.com
server name in1.msg.vip.re2.yahoo.com
server name data1.my.vip.sc5.yahoo.com
server name address1.pim.vip.mud.yahoo.com
server name edit.messenger.yahoo.com
server name messenger.yahoo.com
server name http.pager.yahoo.com
server name privacy.yahoo.com
server name csa.yahoo.com
server name csb.yahoo.com
server name csc.yahoo.com
crypto pki trustpoint TP-self-signed-4227729276
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4227729276
revocation-check none
crypto pki certificate chain TP-self-signed-4227729276
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34323237 37323932 3736301E 170D3132 30343137 31373035
  32395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 32323737
  32393237 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BD97 9407A326 2B2C5E3E 1BEE848C 9DBA6E5E 359E481A 125294BA 19CCF853
  7CEE2B90 58275061 CAD3EEB6 F89CB220 15343AE9 B1BAF818 C94D3036 568EF9F8
  4280497F D1C3579F B8D2AB67 F523FE6A E651DC48 C60E85FC 5361997C 77ACF34A
  F344A000 5E8CDBC9 AB557E60 FC456A08 35B252AC C4CAD14C 181EB7AC AE75CA50
  7A9D0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1483B6F0 CE5D321D CBA30EF9 A22617C3 04676E73 4C301D06
  03551D0E 04160414 83B6F0CE 5D321DCB A30EF9A2 2617C304 676E734C 300D0609
  2A864886 F70D0101 04050003 81810070 B2068055 2153AFFA 3CE445DF B622BCB1
  326AF711 82FC2497 F835F1DA 3F5D367D 99D6342B 4AC087FA 7621945E 9CCBCD90
  994A9B7E 8C8F618B 10E78F0B 8EAAC97F 2C093E65 1B8BC3EB F88C0BB2 D4A4BF7F
  D9C98500 EB16A386 ED160B52 469A3AE4 575FFD45 511CAE55 45AC5D97 2D07F8FD
  6BCE51AC 8150977E 2BC9D8A5 BF3C80
            quit
license udi pid CISCO1921/K9 sn FTX1448Y05L
redundancy
no ip ftp passive
class-map type inspect match-any SDM_BOOTPC
match access-group name SDM_BOOTPC
class-map type inspect match-any LANMan
description LAN Management
match protocol https
match protocol icmp
match protocol ssh
class-map type inspect imap match-any ccp-app-imap
match  invalid-command
class-map type inspect match-any ccp-cls-protocol-p2p
match protocol edonkey signature
match protocol gnutella signature
match protocol kazaa2 signature
match protocol fasttrack signature
match protocol bittorrent signature
class-map type inspect match-any SDM_DHCP_CLIENT_PT
match class-map SDM_BOOTPC
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any sdm-cls-bootps
match protocol bootps
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect gnutella match-any ccp-app-gnutella
match  file-transfer
class-map type inspect match-any DesktopAdmin
description Desktop Administrator Services
match protocol http
match protocol icmp
match protocol snmp
match protocol ssh
match protocol user-RemoteDesktop
class-map type inspect match-any user-ldap
match protocol user-ldap
class-map type inspect ymsgr match-any ccp-app-yahoo-otherservices
match  service any
class-map type inspect msnmsgr match-any ccp-app-msn-otherservices
match  service any
class-map type inspect match-any DomainTrafficUDP
description UDP Traffic
match protocol netbios-ns
match protocol kerberos
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-cls-protocol-im
match protocol ymsgr yahoo-servers
match protocol msnmsgr msn-servers
match protocol aol aol-servers
class-map type inspect aol match-any ccp-app-aol-otherservices
match  service any
class-map type inspect match-all ccp-protocol-pop3
match protocol pop3
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any DomainServerTraffic
description Server Ports
match protocol dns
match protocol ntp
match protocol msrpc
match protocol netbios-dgm
match protocol user-RPC
match protocol user-GlobalCatalog
match protocol user-SMB
match protocol user-DFSR
match protocol ldap
match protocol ldaps
match protocol smtp
match protocol user-WINS
match protocol user-NetBiosNR
match protocol user-SOAP
match protocol netbios-ssn
match protocol microsoft-ds
class-map type inspect pop3 match-any ccp-app-pop3
class-map type inspect kazaa2 match-any ccp-app-kazaa2
match  file-transfer
class-map type inspect match-all ccp-protocol-p2p
match class-map ccp-cls-protocol-p2p
class-map type inspect match-any ccp-h323-inspect
match protocol h323
match  service text-chat
class-map type inspect match-all ccp-protocol-im
match class-map ccp-cls-protocol-im
class-map type inspect match-all ccp-invalid-src
match access-group 103
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect edonkey match-any ccp-app-edonkey
match  file-transfer
match  text-chat
match  search-file-name
class-map type inspect match-any ccp-dmz-protocols
match protocol dns
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-dmz-traffic
match access-group name dmz-traffic
match class-map ccp-dmz-protocols
class-map type inspect edonkey match-any ccp-app-edonkeydownload
match  file-transfer
class-map type inspect match-all ccp-protocol-imap
match protocol imap
class-map type inspect edonkey match-any ccp-app-edonkeychat
match  text-chat
class-map type inspect fasttrack match-any ccp-app-fasttrack
match  file-transfer
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect sdm-cls-bootps
  pass
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect p2p ccp-action-app-p2p
class type inspect edonkey ccp-app-edonkeychat
  log
  allow
class type inspect edonkey ccp-app-edonkeydownload
  log
  allow
class type inspect fasttrack ccp-app-fasttrack
  log
  allow
class type inspect gnutella ccp-app-gnutella
  log
  allow
class type inspect kazaa2 ccp-app-kazaa2
  log
  allow
policy-map type inspect im ccp-action-app-im
class type inspect aol ccp-app-aol
  log
  allow
class type inspect msnmsgr ccp-app-msn
  log
  allow
class type inspect ymsgr ccp-app-yahoo
  log
  allow
class type inspect aol ccp-app-aol-otherservices
  log
  reset
class type inspect msnmsgr ccp-app-msn-otherservices
  log
  reset
class type inspect ymsgr ccp-app-yahoo-otherservices
  log
  reset
policy-map type inspect imap ccp-action-imap
class type inspect imap ccp-app-imap
  log
policy-map type inspect pop3 ccp-action-pop3
class type inspect pop3 ccp-app-pop3
  log
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-protocol-imap
  inspect
  service-policy imap ccp-action-imap
class type inspect ccp-protocol-pop3
  inspect
  service-policy pop3 ccp-action-pop3
class type inspect ccp-protocol-p2p
  inspect
  service-policy p2p ccp-action-app-p2p
  inspect
  service-policy im ccp-action-app-im
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
class type inspect SDM_DHCP_CLIENT_PT
  pass
class class-default
  drop
policy-map type inspect ccp-permit-dmzservice
class type inspect ccp-dmz-traffic
  inspect
class class-default
  drop log
policy-map type inspect LANMgmt
class type inspect LANMan
  inspect
class class-default
  drop log
policy-map type inspect DomainServices-Inspect
class type inspect DomainTrafficUDP
  pass log
class type inspect DomainServerTraffic
  inspect
class class-default
  drop log
policy-map type inspect DesktopServices
description Remote Access and Desktop diag
class type inspect DesktopAdmin
  inspect
class class-default
  drop log
zone security dmz-zone
zone security in-zone
zone security out-zone
zone security LAN
zone security INT-Servers
zone security App-Servers
zone-pair security ccp-zp-out-dmz source out-zone destination dmz-zone
service-policy type inspect ccp-permit-dmzservice
zone-pair security ccp-zp-out-self source out-zone destination self
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-in-dmz source in-zone destination dmz-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security In-LAN source in-zone destination LAN
service-policy type inspect LANMgmt
zone-pair security INTServers-Out source INT-Servers destination out-zone
zone-pair security INZone-zp-INT-Servers source in-zone destination INT-Servers
service-policy type inspect DesktopServices
zone-pair security INTServers-zp-InZone source INT-Servers destination in-zone
service-policy type inspect DomainServices-Inspect
interface Loopback0
ip address 192.168.2.1 255.255.255.255
interface GigabitEthernet0/0
description $ETH-WAN$$FW_OUTSIDE$
ip address dhcp client-id GigabitEthernet0/0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
zone-member security out-zone
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description NOC Link$ETH-LAN$$FW_INSIDE$
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
zone-member security in-zone
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/0/0
switchport mode trunk
interface GigabitEthernet0/0/1
interface GigabitEthernet0/0/2
interface GigabitEthernet0/0/3
interface Vlan1
description $MGMT$
ip address 192.168.101.1 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
zone-member security LAN
interface Vlan5
description $Int-Servers$
ip address 192.168.5.1 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
zone-member security INT-Servers
interface Vlan10
description $Ext-Servers$$FW_DMZ$
ip address 192.168.10.1 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
zone-member security dmz-zone
interface Vlan25
description $App-Servers$
ip address 192.168.25.1 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
zone-member security App-Servers
interface Vlan100
description $Usr-Desktops$
ip address 192.168.100.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip forward-protocol nd
no ip http server
ip http access-class 4
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source list 3 interface GigabitEthernet0/0 overload
ip access-list extended SDM_BOOTPC
remark CCP_ACL Category=0
permit udp any any eq bootpc
ip access-list extended SwitchToDNS
remark CCP_ACL Category=128
permit ip host 192.168.101.2 host 192.168.1.3
permit ip host 192.168.101.2 host 192.168.1.6
ip access-list extended dmz-traffic
permit ip any host 192.168.10.2
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 remark HTTP Access-class list
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 2 deny   any
access-list 3 remark CCP_ACL Category=2
access-list 3 permit 192.168.100.0 0.0.0.255
access-list 3 permit 192.168.101.0 0.0.0.15
access-list 3 permit 192.168.5.0 0.0.0.15
access-list 3 permit 192.168.10.0 0.0.0.15
access-list 3 permit 192.168.25.0 0.0.0.15
access-list 4 remark Auto generated by SDM Management Access feature
access-list 4 remark CCP_ACL Category=1
access-list 4 permit 192.168.1.0 0.0.0.255
access-list 100 remark Auto generated by SDM Management Access feature
access-list 100 remark CCP_ACL Category=1
access-list 100 permit tcp 192.168.1.0 0.0.0.255 host 192.168.1.1 eq 22
access-list 100 permit tcp 192.168.1.0 0.0.0.255 host 192.168.1.1 eq 443
access-list 100 permit tcp 192.168.1.0 0.0.0.255 host 192.168.1.1 eq cmd
access-list 100 deny   tcp any host 192.168.1.1 eq telnet
access-list 100 deny   tcp any host 192.168.1.1 eq 22
access-list 100 deny   tcp any host 192.168.1.1 eq www
access-list 100 deny   tcp any host 192.168.1.1 eq 443
access-list 100 deny   tcp any host 192.168.1.1 eq cmd
access-list 100 deny   udp any host 192.168.1.1 eq snmp
access-list 100 permit ip any any
access-list 101 remark Auto generated by SDM Management Access feature
access-list 101 remark CCP_ACL Category=1
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 remark Auto generated by SDM Management Access feature
access-list 102 remark CCP_ACL Category=1
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 103 remark CCP_ACL Category=128
access-list 103 permit ip host 255.255.255.255 any
access-list 103 permit ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip 192.168.10.0 0.0.0.15 any
control-plane
line con 0
line aux 0
line vty 0 4
access-class 102 in
privilege level 15
password 7 9ASD9RSDEF9SDFT5
login local
transport input ssh
transport output ssh
line vty 5 15
access-class 101 in
privilege level 15
login local
transport input ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp server 208.66.175.36 prefer source GigabitEthernet0/0
ntp server 64.90.182.55 prefer source GigabitEthernet0/0
ntp server 96.47.67.105 prefer source GigabitEthernet0/0
end
Everyone's tags (5)
Silver
add this to your configurations:
access-list 100 permit udp 192.168.5.0 0.255.255.255 192.168.1.0 0.255.255.255
Posted by WebUser Neeraj Jagga from Cisco Support Community App
Re: Firewall on 1921 K9 blocking UDP traffic it should be allowi
Will this allow all UDP communication or only communication on the UDP ports defined in the policy map?
I added this to the running config and tested the ports still return the filtered value. I already opened the ports in the windows firewall so I dont think thats causing the problem.
722
