10-14-2013 08:04 AM - edited 03-07-2019 04:01 PM
We have maintained a data network for a company that cosists of 8 WS-C2960-24TC-S and WS-C2960-48TC-S switches, and a CISCO1921/K9router. Our client's phone vendor has chosen to implement Allworx IP phones. They are requring the following topology: Catalyst Sw > Allworx IP Phone > Workstation. switchport voice vlan x and spanning-tree portfast have been configured on the connecting interfaces. The Allworx phones are being successfully placed in the voice VLAN via CDP.
The phone vendor has come back to me with two major issues:
1. The phones have an echo.
2. After a few minutes of being restarted, the phones' buttons start blinking erratically.
The phone vendor requested I deploy broadcast/multicast storm control. I have applied storm-control broadcast level x and storm-control-multicast level x on all interfaces with no difference. show storm-control revels 0% usage. After telling the phone vendor this, they want me to deploy QoS on all access switches. As I have never done this before, I am currently researching on how to do this.
My goals are to give all traffic on the voice vlan / voice traffic higher precedence/priority to avoid delay, jitter, echo, etc. Also, I do not have access to their equipment.
Is there an example configuration I can refer to, or some pointers, so I can implement my goals listed above? I am planning on studying for CCNP Switch soon, but unfortunately need this deployed immediately.
Thank you
10-14-2013 08:27 AM
Hi John,
You can try applying an inbound service policy to these switch ports using MQC (Modular QoS CLI)
For example, assuming the following details about IP Phone
IP Phone Subnet: 192.168.0.0/24
First configure an extended ACL to match traffic originated from IP Phone
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
Next, create a class-map and call the ACL under this as a match criteria,
class-map IP_PHONE
match access-group 101
Then create a Policy map and call the class-map "IP_PHONE" under this and assign DSCP value as CS5
policy-map IP_PHONE
class IP_PHONE
set dscp cs5
Finally apply this policy-map to the switch ports.
int fa0/1
service-policy input IP_PHONE
This will ensure that all traffic from IP phones are marked with CS5 which by default will be handled as high priority traffic in switch Queues.
Rajmohan R
10-14-2013 09:00 AM
Unfortunately, I am running C2960-LANLITEK9-M software so I have neither the class-map or policy-map commands.
10-14-2013 12:54 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It's often unusual to need QoS enabled on LAN switches, and on the 2960 series, enabling QoS can easily reduce performance because of default buffer sharing. However, as you are sharing the same port for both the VoIP phone and the workstation, port QoS might be needed to keep a busy workstation from being adverse to the VoIP phone.
I'm concerned with your 1921. Cisco only recommends the 1921 for up to 15 Mbps of WAN bandwidth (although this is a conservative rating). It's easy to overload a small ISR used for LAN routing. It's also easy to congest on low bandwidth WAN links.
BTW, I have seen issues where some VoIP phones don't deal well with busy workstations that transit through them.
10-14-2013 01:12 PM
Ok. At this point let me re-phrase my question. How can I accomplish what Rajmohan is suggesting with the C2960-LANLITEK9-M image?
10-14-2013 06:39 PM
What version of IOS?
10-15-2013 06:27 AM
12.2(55)SE5
10-15-2013 07:51 AM
Update:
I mapped the phone's CoS value (7) to ingress queue #2
mls qos srr-queue input cos-map queue 2 7
And gave the queue 10% bandwidth
mls qos srr-queue input priority-queue 2 bandwidth 10
I am a little confused on the threshold values. If queue 1 uses 100% of it's queue (90 Mbps), will it drop packets to reserve the 10% priority set in queue 2, or do I need to configured threshold values (WTD) to get this functionality?
SW1#show mls qos maps cos-input-q
Cos-inputq-threshold map:
cos: 0 1 2 3 4 5 6 7
queue-threshold: 1-1 1-1 1-1 1-1 1-1 2-1 1-1 2-1
SW1#show mls qos input-queue
Queue : 1 2
buffers : 90 10
bandwidth : 4 4
priority : 0 10
threshold1: 100 100
threshold2: 100 100
Thank you
10-15-2013 11:17 AM
Disclaimer
Posting
That ingress queue is for fabric access, you shouldn't need to change that.
LAN-Lite says it supports QoS, but from the documentation I briefly reviewed, limitations aren't well defined.
If you cannot use "typical" port ingress QoS, perhaps you can use VLAN based QoS and just tagged all your VoIP traffic as desired. VoIP phones usually can tag their traffic, and if they do, you would need to concern yourself with different traffic treatment based on ToS markings. Again, this can be somewhat tricky on a low end switch and often isn't needed on such switches.
