Flase-Car
Guys,
Is there anywhere I can find some explanation to the False-Car occurance in the "show int counters errors module 3 | begin False-Car" output.
I can see huge amount of it, currently it shows 4294967296
1 REPLY
Re: Flase-Car
False-Car = False Carriers.
It is generally caused when the device on this port is disconnected/connected or power down/up.
It could also indicate something wrong with physical layer. You can try the following:
1. replace the cable
2. move to a diff switch port.
3. Check the NIC card and might be upgrade its driver.
434
