12-14-2007 12:56 PM - edited 03-05-2019 08:00 PM
Anyone know what this flash card is used for? Does it hold the nvram as opposed to other boxes (2500, 2600) where its built in to the system?
12-14-2007 12:59 PM
The flash card is used to hold copy of the IOS/startup config etc. Yes it is built in on some of the older models.
Jon
12-14-2007 03:26 PM
Hi, thanks for the response.
When you state it leaves a copy, do you mean a duplicate of the iso and config or does it store the actual ios/config? meaning that the device is useless without the card...?
12-14-2007 03:30 PM
Yes, you need the card because this is the only flash.
Jon
