Flash deleted on Cat 2950
I have deleted the flash memory of my cat 2950, and I need help finding the instructions, step by step on how to load a new flash.
I have already downloaded the IOS c2950-i6q4l2-mz.121-22.EA8a on to my desktop.
If I load this IOS, will I fix the flash issue?
1 REPLY
Re: Flash deleted on Cat 2950
Hi Friend,
Can you confirm if the switch is in rommon mode or you still on switch prompt?
If you still have the access of the switch and it is not in rommon you can attempt tftp upgrade, this link will help you with the same
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea5/configuration/guide/swiosfs.html#wp1086981
If you are in rommon this link will help you with the same
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
Ankur
*Pls rate all helpfull post
153
