12-02-2009 03:34 PM - edited 03-06-2019 08:48 AM
All, I have a flash question. I need to format a flash drive. Are these flashes hot swappable? I mean, can I take a flash out of an 1841 and put another one in without powering it off and put another image onto it? Thanks in advance for the help.
Solved! Go to Solution.
12-02-2009 04:15 PM
Yes, you can. After you put the new IOS on it, then you have to reboot the box to load it from the new image.
Reza
12-02-2009 04:15 PM
Reza
12-02-2009 04:35 PM
You can also try using USB. Maximum limit is 2Gb.
12-02-2009 06:22 PM
all, thank you.
