Flash memory format
All, I have a flash question.  I need to format a flash drive.  Are these flashes hot swappable?  I mean, can I take a flash out of an 1841 and put another one in without powering it off and put another image onto it?  Thanks in advance for the help.
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: Flash memory format
Yes, you can.  After you put the new IOS on it, then you have to reboot the box to load it from the new image.
Reza
VIP Super Bronze
Reza
Hall of Fame Super Gold
You can also try using USB.  Maximum limit is 2Gb.
all, thank you.
245
