08-24-2010 01:06 AM - edited 03-06-2019 12:37 PM
Hi everybody,
I cannot find 'switchport backup interface' command on NX-OS Release 4.2. Is Flex Links feature still supported on Nexus 7000?
If I want to provide layer 2 redundancy without using Spanning-Tree or vPC is there any other solution to use?
Stefano
Solved! Go to Solution.
08-24-2010 01:26 AM
Flexlink is not supported on N7K. Why do you not want to use vPC?
Atif
08-24-2010 01:26 AM
Atif
12-10-2018 01:35 PM
I had the same question (feature support on the 7k). My use case is I'm migrating off of 2 stand-alone switches with a trunk in between and wanted to uplink to both without spanning-tree. It's supported on 5ks....just not 7k :(
