Flexible netflow problem on ASR 1001
We have configured following flexible netflow on our ASR router
flow monitor FLOW-MONITOR-1
cache entries 1024
record netflow ipv4 original-output
WAN Interface
ip flow monitor FLOW-MONITOR-1 output
However we are not able to get our required show related command like below
BUR-ASR01-L2-L3# show flow monitor FLOW-MONITOR-1 ca
BUR-ASR01-L2-L3# show flow monitor FLOW-MONITOR-1 cache ?
format Specify cache display format
| Output modifiers
<cr>
NOTE: In document there are other options like filter, aggregation and sort options but in our ASR we are not seeing them.
Following is the show version output for the configured ASR
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 1
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 15-Feb-12 21:55 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2012 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BUR-ASR01-L2-L3 uptime is 11 weeks, 6 days, 11 hours, 38 minutes
Uptime for this control processor is 11 weeks, 6 days, 11 hours, 39 minutes
System returned to ROM by reload at 04:54:16 ast Tue May 22 2012
System restarted at 12:57:59 ast Tue May 22 2012
System image file is "bootflash:/asr1001-universalk9.03.05.01.S.152-1.S1.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Info:
License UDI:
Device# PID SN UDI
*0 ASR1001 JAE15500814 ASR1001:JAE15500814
License Package Information for Module:'asr1001'
Module name Image level Pri Config Valid license
asr1001 adventerprise 1 NO adventerprise
advipservices 2 NO advipservices
ipbase 3 NO ipbase
Module name Current Level Reboot Level
asr1001 advipservices advipservices
cisco ASR1001 (1RU) processor with 1179685K/6147K bytes of memory.
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7782399K bytes of eUSB flash at bootflash:.
Please advise.
Everyone's tags (5)
655
