Floating static routes with IP SLA - 3G connection
Ron Lewis
                   I am working on a Cisco 1921 router with a 4G connection as the primary link and a 3G connection as a secondary.
I have not been able to get IP SLA with floating static routes to fail over when shutting down the primary interface. I have looked at a number of examples here and would like to know if it is possible to backup a wireless connection with a secondary wireless connection on a Cisco router
I have included my config and would appreciate any feedback.
controller Cellular 0/0
controller Cellular 0/1
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
track 1 ip sla 1 reachability
interface GigabitEthernet0/0
description LAN
ip address 192.168.127.253 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface Cellular0/0/0
Description 4G
ip address negotiated
ip access-group IN-FROM-INTERNET in
ip access-group OUT-TO-INTERNET out
encapsulation slip
dialer in-band
dialer pool-member 1
async mode interactive
interface Cellular0/1/0
Description 3G
ip nat outside
encapsulation slip
dialer in-band
dialer pool-member 2
dialer-group 2
interface Dialer0
description 4G
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string lte
dialer persistent
dialer-group 1
interface Dialer1
description 3G
ip nat outside
encapsulation ppp
dialer pool 2
dialer string hspa   dialer persistent
dialer-group 2
no cdp enable
ip dns server
ip nat inside source static udp 192.168.127.2 53 interface Dialer0 53
ip nat inside source route-map PRIMARY interface Dialer0 overload
ip nat inside source route-map SECONDARY interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1
ip route 0.0.0.0 0.0.0.0 Dialer1 50
ip access-list extended IN-FROM-INTERNET
evaluate Internet
remark VPN-Traffic
permit udp any any eq isakmp
permit udp any any eq isakmp non500-isakmp
permit udp any any eq 10000
permit tcp any any eq 10000
permit esp any any
permit ahp any any
permit udp any any eq domain
deny   ip any any
ip access-list extended OUT-TO-INTERNET
permit ip any any reflect Internet timeout 300
ip sla auto discovery
ip sla 1
icmp-echo 8.8.8.8 source-interface Cellular0/0/0
threshold 150
timeout 200
frequency 2
ip sla schedule 1 life forever start-time now
access-list 1 permit 192.168.127.0 0.0.0.255
access-list 2 permit 192.168.127.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map PRIMARY permit 1
match ip address 1
match interface Dialer0
route-map SECONDARY permit 1
match ip address 1
match interface Dialer1
snmp-server community public RO
snmp-server enable traps entity-sensor threshold
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 0/0/0
script dialer lte
modem InOut
no exec
transport input all
transport output all
rxspeed 100000000
txspeed 50000000
line 0/1/0
script dialer hspa
modem InOut
no exec
transport input all
rxspeed 21600000
txspeed 5760000
line 0/1/1
no exec
line vty 0 4
password 7
transport input all
scheduler allocate 20000 1000
end
11 Replies 11
Richard Burts
Your IP SLA is sending ICMP out the cellular0 interface. But your access list ip access-list extended IN-FROM-INTERNET  does not have any permit for ICMP traffic.
Rick
Rick
Thanks Rick, I will ammend the ACL and re-test
I permitted ICMP on the ACL IN-FROM-INTERNET but the failover still didn't work. I found that while I had my ACL's applied to the Cellular interface I was not getting any hits on them. I moved them to the dialer interface and could then see the ACL's getting matches.
I set the IP SLA to track on the cellular interface and then tried tracking on the dialer interface but still no result.
Can you remove both ACLs from the Cellular0/0/0 interface, and try it again? This will quickly rule out the ACLs.
Removing both ACL would be a reasonable test to determine whether there is something in the ACL that is causing this issue. If removing the ACL does not resolve then perhaps you would post the current config and also the output of show ip sla summ?
Rick
Rick
Thanks for the replies, I will re-test with no ACLs and let you know the outcome.
Current configuration : 7612 bytes
version 15.2
service password-encryption
hostname jrrtwalker
boot-start-marker
boot-end-marker
enable secret 5
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
clock timezone CST 9 30
ip cef
ip domain name jrrtwalker.local
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
chat-script lte "" "AT!CALL1" TIMEOUT 60
chat-script hspa "" "AT!SCACT=1,1" TIMEOUT 60 "OK"CONNECT
license udi pid CISCO1921/K9 sn FGL172022NY
license accept end user agreement
redundancy
ip ssh time-out 60
ip ssh version 2
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group VPN-Staff
  pool VPN-Connections
acl VPN-Staff
crypto isakmp client configuration group VPN-Contractor
acl VPN-Contractor
crypto isakmp client configuration group VPN-QHSE
acl VPN-QHSE
crypto isakmp profile VPN-Staff
   match identity group VPN-Staff
   client authentication list userauthen
   isakmp authorization list groupauthor
   client configuration address respond
   virtual-template 10
crypto isakmp profile VPN-Contractors
   match identity group VPN-Contractor
   virtual-template 11
crypto isakmp profile VPN-QHSE
   match identity group VPN-QHSE
   virtual-template 12
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode tunnel
crypto ipsec transform-set myset esp-3des esp-md5-hmac
mode tunnel
crypto ipsec profile IPSEC-Contractors
set transform-set myset
set isakmp-profile VPN-Contractors
crypto ipsec profile IPSEC-QHSE
set isakmp-profile VPN-QHSE
crypto ipsec profile IPSEC-Staff
set isakmp-profile VPN-Staff
interface Embedded-Service-Engine0/0
no ip address
shutdown
ip nat inside
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip nat outside
encapsulation slip
dialer in-band
dialer-group 1
ip nat outside
encapsulation slip
dialer in-band
dialer-group 2
interface Cellular0/1/1
no ip address
encapsulation slip
interface Virtual-Template10 type tunnel
description --- Template for VPN-Staff ---
ip unnumbered GigabitEthernet0/0
ip nat inside
tunnel mode ipsec ipv4
tunnel protection ipsec profile IPSEC-Staff
interface Virtual-Template11 type tunnel
description --- Template for VPN-Contractors ---
ip nat inside
tunnel protection ipsec profile IPSEC-Contractors
interface Virtual-Template12 type tunnel
description --- Template for VPN-QHSE ---
ip nat inside
tunnel protection ipsec profile IPSEC-QHSE
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer string lte
dialer persistent
dialer-group 1
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 2
dialer string hspa
dialer persistent
dialer-group 2
no cdp enable
ip local pool VPN-Connections 192.168.127.240 192.168.127.245
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip route 0.0.0.0 0.0.0.0 Dialer1 100
evaluate Internet
remark VPN-Traffic
permit esp any any
permit ahp any any
permit tcp any any eq 22
permit icmp any any
remark DNS
permit icmp any any echo-reply log
deny   ip any any
permit icmp any any
deny   ip any any log
ip access-list extended VPN-Contractor
permit ip host 192.168.127.104 any
permit ip host 192.168.127.105 any
permit ip host 192.168.127.106 any
permit ip host 192.168.127.107 any
ip access-list extended VPN-QHSE
permit ip host 192.168.127.4 any
ip access-list extended VPN-Staff
permit ip 192.168.127.0 0.0.0.255 any
ip access-list extended acl_nat
permit ip 0.0.0.0 255.255.255.0 any
ip sla 1
threshold 2
timeout 1000
frequency 3
match ip address 1
match ip address 1
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line 0/0/0
script dialer lte
modem InOut
no exec
transport input all
rxspeed 100000000
txspeed 50000000
line 0/1/0
script dialer hspa
modem InOut
no exec
transport input all
rxspeed 21600000
txspeed 5760000
line 0/1/1
no exec
line vty 0 4
exec-timeout 0 0
password 7 11232B3723252A202F0F19277D67667A4B
transport input all
end
jrrtwalker#sh ip sla st
jrrtwalker#sh ip sla statistics
IPSLAs Latest Operation Statistics
IPSLA operation id: 1
        Latest RTT: 0 milliseconds
Latest operation start time: 19:06:39 CST Sun Nov 3 2013
Latest operation return code: Socket set option error
Number of successes: 0
Number of failures: 44147
Operation time to live: Forever
jrrtwalker#sh ip route tr
jrrtwalker#sh ip route track-table
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1 state is [down]
jrrtwalker#
version 15.2
hostname jrrtwalker
boot-start-marker
boot-end-marker
enable secret 5
aaa new-model
ip cef
no ipv6 cef
redundancy
ip ssh time-out 60
ip ssh version 2
encr 3des
group 2
acl VPN-Staff
acl VPN-Contractor
acl VPN-QHSE
   virtual-template 10
   virtual-template 11
   virtual-template 12
mode tunnel
mode tunnel
no ip address
shutdown
ip nat inside
duplex auto
speed auto
no mop enabled
no ip address
shutdown
duplex auto
speed auto
ip nat outside
encapsulation slip
dialer in-band
dialer-group 1
ip nat outside
encapsulation slip
dialer in-band
dialer-group 2
no ip address
encapsulation slip
ip nat inside
ip nat inside
ip nat inside
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer string lte
dialer persistent
dialer-group 1
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 2
dialer string hspa
dialer persistent
dialer-group 2
no cdp enable
no ip http server
ip dns server
evaluate Internet
remark VPN-Traffic
permit esp any any
permit ahp any any
permit icmp any any
remark DNS
deny   ip any any
permit icmp any any
deny   ip any any log
ip sla 1
threshold 2
timeout 1000
frequency 3
match ip address 1
match ip address 1
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line 0/0/0
script dialer lte
modem InOut
no exec
transport input all
rxspeed 100000000
txspeed 50000000
line 0/1/0
script dialer hspa
modem InOut
no exec
transport input all
rxspeed 21600000
txspeed 5760000
line 0/1/1
no exec
line vty 0 4
exec-timeout 0 0
transport input all
You also need a local policy to prevent SLA probes exit on the secondary interface after failover.
Reliable Static Routing Backup Using Object Tracking
ip route 0.0.0.0 0.0.0.0 Dialer0                                   <------ remove this
Following changes made
Removed ip route 0.0.0.0 0.0.0.0 Dialer0  so only the following routes are left:
removed ACLs from Cell interfaces
I also change the IP SLA config to use the dialer 0 interface instead of the cell interface.
I shut down the dialer 0 interface and the dialer 1 interface was updated in the route table so this was a success.
However when I brought the dialer 0 interface I could not get it to fail back to the primary dialer 0 interface.
I tried then shutting down the dialer 1 interface which killed everything.
The only way I could force the traffic back through the dialer 0 interface was to add a default route via dialer 0 with no tracking, e.g. ip route 0.0.0.0 0.0.0.0 dialer0.
Thanks for the update. I am sorry that the test results were not more positive. In looking at what you posted I notice this in the output of show ip sla statistics
So something is not working with ip sla and in that case tracking for the route will not work as well. So we need to figure out what is the issue with ip sla. Perhaps the output of show ip sla summ might help. And perhaps the current config - at least the parts about ip sla since you did make some changes.
Rick
Rick
Three things:
1. Configure an echo service for "ip sla 1" and "ip sla 2" for the source-interfaces (which has already been done for one interface).
2. Check the next-hop availability command using (I guess this is the command) "set ip next-hop x.x.x.x verify-availability 1 track 1" command.[Again, I am unsure of this command, so please forgive me]. Do this for both the interfaces. x.x.x.x is the next hop for the ISP(I think you can also set this as some google dns, should work).
3. Set the next hop availability command for both IP SLAs under both lan interfaces using the route-map.
This should work.
HTH.
P.S. I am quite rusty with IP SLA configuration
Have you added
ip local policy route-map
to make sure that SLA probes to 8.8.8.8 always exit on Dialer0? Study the linked guide.
I don't think Arun Nair's 3 points are necessary.
