10-25-2007 03:10 AM - edited 03-05-2019 07:18 PM
I had 12416 router with Modular SPA Interface Card (10G) card
on one of its port it shows flow control off and on other it shows on. How can I make it off
CHD-ISP-COR-RTR-22#sh int gigabitEthernet 4/0/2
GigabitEthernet4/0/2 is up, line protocol is up
Hardware is GigabitEthernet, address is 0019.2f42.6202 (bia 0019.2f42.6202)
MTU 1500 bytes, BW 110592 Kbit, DLY 10 usec, rely 255/255, load 226/255
Keepalive set (10 sec)
Full Duplex, 1000Mbps, link type is autonegotiation, media type is SX
output flow-control is off, input flow-control is off
CHD-ISP-COR-RTR-22#sh int gigabitEthernet 4/0/3
GigabitEthernet4/0/3 is down, line protocol is down
Hardware is GigabitEthernet, address is 0019.2f42.6203 (bia 0019.2f42.6203)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, rely 255/255, load 1/255
output flow-control is on, input flow-control is on
Pl. suggest
Mahesh
10-25-2007 03:55 AM
flowcontrol receive off
flowcontrol send off
Kevin Dorrell
Luxembourg
10-25-2007 04:15 AM
CHD-ISP-COR-RTR-22(config)#int gigabitEthernet 4/0/3
CHD-ISP-COR-RTR-22(config-if)#flo
CHD-ISP-COR-RTR-22(config-if)#flow ?
% Unrecognized command
this command is not working
Pl. suggest
10-25-2007 04:55 AM
I've just seen this is a 12000 so I may be out of my depth. Is it XR?
If it was my 4500, I would do show int G4/0/3 capabilities to check my options, and look for the flow control capabilities. It is always possible that it does not suppport static configuration and the only option is "desirable". If that is the case, then it depends entirely what is at the other end of the link.
Kevin Dorrell
Luxembourg
10-25-2007 05:10 AM
this comand is not working
Mahesh
10-25-2007 05:13 AM
I guess it is XR then, and I really cannot help you. Sorry.
