Ask the Expert- configuration and troubleshoot WSA and https proxy
Community Member
forwarding broadcast-wol
For wol development I need to forwarding broadcast. The configuration is:
The wol server is in vlan 50. The stations are in vlan 50
ip forward-protocol udp 12287
interface Vlan50
ip address xxx.xxx.xxx.xxx
no ip redirects
ip directed-broadcast 101
no ip proxy-arp
The problem is that I see in the switch where there are the workstations, a broadcast that have the origen mac-address in vlan 52. The switch know this vlan, so, the stations in vlan 50 don't receive the brodacast.
Can somebody help me with an idea?
Thanks.
Marcelo
Re: forwarding broadcast-wol
Are you trying to know why you can't get broadcast from VLAN 50 in VLAN 52?
If so, VLANs divide broadcast domains.
Hall of Fame Super Bronze
Marcelo,
You need to use the ip helper-adress command in conjunction with the ip forward-protocol command to take the broadcast packet from one Vlan to another in form of unicast.
I'm not sure if it will work for Wake-On Lan packets but it's worth a try.
http://www.cisco.com/en/US/docs/ios/ipapp/command/reference/iap_i1.html#wp1053151
HTH,
__
Edison.
Community Member
814
