03-24-2007 01:16 PM - edited 03-05-2019 03:05 PM
Hi all, If I have a multipoint connection at site A, with a multipoint interface with various maps, on the spoke sites, can we just set it up on the serial interface and just use encap frame-relay, or do I have to map it ?
03-24-2007 09:23 PM
Hi Carl,
On the spoke router you will NOT have to map the IP address/DLCI of the hub router. However, if you have other spoke sites on the same subnet which you need direct connectivity to then these will have to be mapped statically.
Mike.
Cisco TAC.
03-25-2007 03:31 AM
can someone show me an example config for this ?
