03-05-2007 07:44 PM - edited 03-05-2019 02:43 PM
We currently have a Frame relay Network comprised of 80 plus sites running EIGRP. We will be migrating to an MPLS network soon using Juniper Routers. Are there any recommendations on how best to accomplish this??? Any help would be greatly appreciated.
03-05-2007 09:43 PM
For handy commands for Juniper/Cisco look here:
http://networking.ringofsaturn.com/Cisco/ciscojuniper.php
Cisco can work well in a mixed vendor enviroment and so can juniper ... the think is that you need to do some propper testing ...
If you find this post usefull
please don't forget to rate this
#Iwan Hoogendoorn
03-06-2007 05:45 AM
Since the MPLS network will be using BGP would it be better to enable OSPF on the Cisco Frame routers along side EIGRP and then do some redistribution or would it be better to use static routes?? Is there a best practice design for this scenerio???
