11-22-2006 02:13 AM - edited 03-05-2019 12:57 PM
Hi all, can anyone tell me what speeds you can get frame relay on in the uk ?
11-22-2006 06:24 AM
Hi Carl,
Normal frame relay usually goes up to around the 2Mbps mark for the access. The standard Cisco serial WIC's top out at 2Mbps as well.
You can have a guaranteed rate (CIR) of anything under that. Probably usually in 16kbps increments.
Depending on how many sites you have - a lot of company's are going for IP WAN style solutions. This way you can have 1 network with different access pipes to each office. Frame relay, DSL, Ethernet. Much more flexible approach.
Cheers,
Tim.
11-22-2006 06:40 AM
Hi Carl,
What speed do you want! you can get anything from 64kbps up to 622Mbps. You can also get Gigabit Ethernet services depending upon the distances involved.
Kevin
11-22-2006 09:30 AM
well, what media can you run frame relay over, does it have to be serial ?
