Community Member
From L2 to routed OSPF, transition
I`m converting a network from L2 to routed.
For various reasons I want to do this without having to cange IP setup for all clients.
Will it work if I set up OSPF between routers and define VLANs with same gateway address.
And then add /32 enteries for each clients in routing table?
Know this will be some work, but it is a lot better than my other option.
1 REPLY
Hall of Fame Super Bronze
This won't work.
Please follow the design per the routed diagram you've posted.
130
