Community Member
ftp break behind CSS 11501
Can you please look at my config and tell me what i did wrong? If i am outside CSS and ftp to xxx.xxx.49.34, everything works fine. If I am behind CSS and ftp to xxx.xxx.49.34, i can still log in but as soon as I run ftp command such as "ls" or "dir", I will get disconnect from ftp server.
Thanks.
1 REPLY
Silver
Re: ftp break behind CSS 11501
Enabling prelogin-banner was one of the causes to disconnect the FTP Server.
If you enabled please disable the prelogin banner.
CSS CLI and reset the default behavior of the
CSS to no pre-login banner,
(config)# no prelogin-banner, then the FTP to the CSS started
working fine.
149
