Community Member
FTP from VLAN1 to VLAN2 on a 3750 catalyst not possible
hi,
on a 3750 catalyst ( Version 12.2(25)SEE2 )
it's not possible to start a FTP from a client in VLAN1 to a server in VLAN2;
is the same client also in VLAN2 than it works fine...
there is no firewall/access list defined...
i get:
ftp> open xxx.xx.xx.xx
connected to xxx.xx.xx.xxx.
connection closed by Remotehost.
ftp>
a telnet and ping xxx.xx.xx.xxx is possible!
any help/idea?
thanks,
martin.
Anonymous
N/A
Re: FTP from VLAN1 to VLAN2 on a 3750 catalyst not possible
What are you using to route between the VLANs? Are you using the 3750 or an external router?
VIP Purple
Martin,
Do you have the command "ip routing" in your config?
Brandon
Highlighted
Community Member
So, if u could ping/telnet it between vlan's, routing is fine.
Is there any acl filtering ftp traffic ?
Best Regards,
Bruno Petrónio
Community Member
1) the routing is done by the switch itself
2) no i have no "access list"
3) yes, i have the parameter ip routing
here the starting from the config:
switch 1 provision ws-c3750g-48ts
switch 2 provision ws-c3750g-48ts
switch 3 provision ws-c3750-48ts
ip subnet-zero
ip routing
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
spanning-tree vlan 1,10-14 priority 24576
vlan internal allocation policy ascending
interface Port-channel1
switchport mode access
spanning-tree portfast
spanning-tree bpdufilter enable
interface Port-channel2
switchport mode trunk
shutdown
interface GigabitEthernet1/0/1
description S1svaEN1
speed 1000
duplex full
thx,
martin
Silver
Hi Martin
Are you sure that the problem is with the 3750?
From the FTP information supplied,
ftp>
it appears that you have been connected to the server and that something on the server has then ended the session.
If there was a routing problem on the 3750 I would have expected something like the following,
H:\>ftp
ftp> open 10.10.10.1
> ftp: connect :Connection timed out
ftp>
If the server is a windows based server, is it possible that there is a local firewall (windows firewall) terminating your FTP session?
Best Regards,
Michael
264
