Webcast-Catalyst9k
Gateway for VLAN traffic
Have several layer 3 entry level switches (sg500x). They have their default VLAN1 plus VLAN2 which I have created and trunked across two of the switches. The trunk port between the switches carries VLAN1 traffic untagged and VLAN2 traffic tagged. I need to give clients on VLAN2 a gateway onto VLAN1 when all the servers are.
I understand most will not be familiar with sg500x cli but I’m looking for concepts of how this is done e.g. do I need to assign an IP in the subnet range for VLAN2 to the trunk port and make that the gateway?
1 ACCEPTED SOLUTION
Hi Rhys,
It looks like the default-gateway is incorrect.
can you perform this test and provide the output of IPCONFIG from the client PC?
Ping 172.16.40.20 sour vlan 1 from switch A
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks & Regards, Karthick Murugan CCIE#39285
Purple
if the switch is operating at layer 3(ip routing enabled ) then you can give hosts in vlan2 the ip address of interface vlan 2 as their default-gateway.
Alain
Thanks Alain
Yes running in layer3 with routing enabled and yes I have tried that. On switch A I have:
VLAN2 interface 172.16.40.10
On switch B I have:
VLAN2 interface 172.16.40.20
So clients connected to VLAN2 on switch A I give gateway 172.16.40.10 and clients in VLAN2 switch B I give gateway 172.16.40.20? I still can’t ping clients on VLAN1 on subnet 172.16.6.0/21
Purple
Have you tried with windows software firewall turned off ?
Alain
Hi, yes all firewalls are off for testing. Clients on same vlan can ping across switches.
Hi Rhys,
can you give the output of 'show ip route" and "show ip int brief' from both the switches?
Thanks & Regards,
Karthick Murugan
CCIE#39285
Karthick -
switchA#show ip route
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding:          enabled
Codes: C - connected, S - static, D - DHCP, R - RIP
C  172.16.0.0/21      is directly connected                        vlan 1
C  172.16.40.0/21     is directly connected                        vlan 2
switchA#show ip int
IP Address         I/F       Type     Directed   Precedence   Status
                                          Broadcast
172.16.6.95/21      vlan 1    Static      disable    No         Valid
172.16.40.10/21     vlan 2    Static      disable    No         Valid
switchB#show ip int
                                          Broadcast
172.16.6.96/21      vlan 1    Static      disable    No         Valid
172.16.40.20/21     vlan 2    Static      disable    No         Valid
switchB#show ip route
Rhys,
Thanks for the info. We need to make sure the L2 path is fine.
Can you ping a client IP address from switch A with sour vlan 1?
ping source vlan 1
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks, no I can't. Traffic will not transverse the VLANs. From VLAN1 to 2 or vice versa.
Purple
Can you post a topology diagram.
Alain
Super Bronze
Re: Gateway for VLAN traffic
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
From the client perspective, your hosts on both VLANs should be in their own subnet.  Ideally, they will also have a gateway address for their own subnet.
On your L3 switches, things can become a bit complex if you have more than one of your L3 capable switches running in L3 mode.  With just a few switches, simplest setup might be to run all your switches as L2 except just one.  On that one, enable L3 and define VLAN interfaces (not just the VLANs) on it.  Each VLAN interface will have the IP you've selected for the gateway.
Thanks Joseph, yes they are on their own subnet. My problem is the gateway. I will take your advice as I progress and disable L3 where I can. All switches are out of the box, configured with an interface IP and chained for the central switch which has servers and internet. Switch A and B are linked on port 3, this link is also a trunk for VLAN2. VLAN2 traffic is tagged, VLAN1 traffic untagged.
Hi Rhys,
Thanks & Regards,
Karthick Murugan
CCIE#39285
Hi Karthick
No reply to ping
Ipconfig of client connected to VLAN1 on switchA pinging interface connection (172.16.40.20/21) of  VLAN2 on switch 2
IP 172.16.1.47
MASK 255.255.248.0
GW – 172.16.6.90 (interface address of core switch which handles some routing off the LAN)
One thing that confuses me is that vlan2 has more than one IP address - ie VLAN2  has an interface address on switch A and an interface address on switch B (which connects the trunk ports either end). If the interface address is to be used as a gateway then when I configure dhcp clients will needsa different gateway depending which switch they are on. Something is obviously wrong here.
Rhys,
If you want one of switches to act as a gateway for the clients then you need to configure HSRP and the virtual-ip can be used for the clients.
SAMPLE CONFIG
SW1
vlan 2
ip address 1.1.1.1 255.255.255.0
standby 1 ip 1.1.1.3
SW2
vlan 2
ip address 1.1.1.2 255.255.255.0
In the DHCp server you can configure 1.1.1.3 as the default-route for the users.
Karthick Murugan
Thanks & Regards,
Karthick Murugan
CCIE#39285
If you see this post
https://supportforums.cisco.com/thread/2241471
He says
"Each VLAN has an ip address and clients have their gateways set as the switches interface address. Intervlan is working and clients can ping across VLANS and access the internet."
This is what I'm trying to achive - the sg500 should be able to route across the vlans by simply enabling routing. I think the crux is when assigning an IP to an interface be it a vlan or a port I'm doing something wrong.
Rhys
Thanks Karthick you were right about the gateway. The clients on VLAN1 are all configured to use SwitchE for gateway as this has routes off to WAN, internet etc so.....I was focusing on the gateway the clients on VLAN2 were using, without considering the clients on VLAN1 needed a gateway local to switchA/B that was aware of VLAN2.
To make Switch E aware of VLAN 2 I guess I need to make trunks back up the uplinks to SwitchE?
Thanks for all contributions from others.
Rhys
Super Bronze
Disclaimer
Posting
From the other information you've posted, you've got gateways on two L3 (?) enabled switches.  For this to work, you'll need to either do static or dynamic routing between your L3 devices.  This is the kind of complexity you might avoid on just a few switches.
239
