Gateway IP address for Cisco 891 Router
To anyone We are switching over to a new ISP and the settings from the old ISP Statstic IP,DNS, is on the Cisco 891 router. Question can I just edit the settings that are already on the Cisco 891 router. I clicked on the CCP exress Went to the Task Internet(Wan) Address type is set for Static IP which I can change and the subnet I can change. In the DHCP it is enable DHCP server on the Lan interface VLan1 and I want to keep the Starting IP address and Ending IP address. For the Section DOmain Name Server (DNS) Primary DNS and Secondary DNS I can change it. Where do I type in the Gateway address. I clicked on the Routing and I only see checked Enable default Route and checked INterface Fastethernet8. I don't see anywhere that I need to type in the Gateway address anywhere in the CCP Express just need help on that part
1 REPLY
Purple
please avoid duplicate posts.
I posted an answer in Wan and routing.
Regards.
Alain.
1148
