GE SFP modules doesn't work with Nexus5596
Hello Experts
I have a Cisco Nexus5596, and it has few copper GE port SFP moduels running on it properly.  Now I tried to plug (hot swap) one more GE port SFP module on it, but it always gave me 'SFP validation failed'.  Tried two SFP moduels, both are same mode as other working on it, 'type is SFP-1000BASE-T, part number is ABCU-5710RZ-CS4', and both worked fine on my 3560.  So it's not a SFP issue.  Also tried different ports on the Nexus5596, got 'spfInvalid' as well.  So what's the issue could be?  Do I have to reboot the Nexus5596 to activate new SFP modules?  Should it be supposed hot swap?
Thanks a lot.
2 ACCEPTED SOLUTIONS
Bronze
I hope you have not forgotten set interface speed using the speed interface subcommand to 1Gbps?
Please see thread:
https://supportforums.cisco.com/thread/2080634 with the same ABCU-5710RZ-CS4 sfp...
There are switchable 1-Gigabit and 10-Gigabit ports. The default interface speed is 10-Gigabit, so you need to set the speed of the port to match the speed of the SFP.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards, Ivan Shirshin **Please grade this post if you find it useful.
Hall of Fame Super Gold
I remembered seeing this before.  If memory serves me correct, there's a possibility your SFP module is V01.  If this is the case, GLC-T is only supported starting from V02.
Bronze
Please see thread:
Thank you.  It worked.
Kind Regards,
Ivan Shirshin
Thank you.  It works.
327
