Community Member
GEC - Connecting switches
Hi All
Please can I configure a Layer 2 or Layer 3 etherchannel on 2 links attached to 2 different switches such as
SwitchA --link1 -- SwitchB
and
SwitchC --link2 -- SwitchD
or do they 2 links have to be on the same switch?
1 REPLY
Re: GEC - Connecting switches
I guess this is not possible as Fast EtherChannel and Gigabit EtherChannel port bundles allow you to group multiple Fast or Gigabit Ethernet ports into a single logical transmission path between the switch and a router, host, or another switch.
check this URL to get more information on etherchannel.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat5000/rel_5_2/config/channel.htm#xtocid252422
hope it helps ... rate if it does ...
135
