get TRUNK Cisco 881 and HP2510
I got some problem getting the trunk up and running as my HP knowledge is limited I’m looking for some expert advice hence the reason I ask it here.
1) is it possible with Cisco 881
2) if possible what the best config at the HP, assuming the cisco is correct please below some excerpt of the config
3) I’ve no admin control on the HP 2510
4) Below are some links about trunk set up between Cisco/HP maybe we misread something
Cisco 881
IOS flash:c880data-universalk9-mz.151-4.M6.bin
HP 2510
ProCurve-2510G-24-SRVRM release #Y.11.12
Problem: getting the Trunk between Cisco 881 and HP2510
Cisco 881 Trunk config
interface FastEthernet3
switchport trunk allowed vlan 1-4,1002-1005
switchport mode trunk
no ip address
spanning-tree portfast
HP 2510 config ( partly)
vlan 3
   name “OFFICE” LAN
   untagged 4,22
   no ip address
   tagged 5-6,14,Trk1-Trk2
   exit
vlan 4
   name “WIFI
   tagged 11-12,14-15,Trk1-Trk2
<snip>
trunk 7-8 Trk1 LACP
trunk 9-10 Trk2 LACP
spanning-tree Trk1 priority 4
spanning-tree Trk2 priority 4
Note: I am aware that LACP is not possible with Cisco 881.
it looks like  the HP2510 con only handle only one LACP or 802.1q,  if that's the case we another challenge
VLAN Trunk Between Cisco and HP Procurve switch
http://premoddev.blogspot.nl/2012/10/vlan-trunk-between-cisco-and-hp.html
Cisco and HP Procurve Trunk 802.1Q
http://itpeopleworld.blogspot.nl/2011/12/cisco-and-hp-procurve-trunk-8021q.html
Trunk between HP switch and Cisco switch
http://forums.whirlpool.net.au/archive/1656353
http://h20565.www2.hp.com/portal/site/hpsc/template.BINARYPORTLET/public/kb/docDisplay/resource.process/?spf_p.tpst=kbDocDisplay_ws_BI&spf_p.rid_kbDocDisplay=docDisplayResURL&javax.portlet.begCacheTok=com.vignette.cachetoken&spf_p.rst_kbDocDisplay=ws...
http://cdn.procurve.com/training/Manuals/ProCurve-and-Cisco-STP-Interoperability.pdf
Trunking between a Cisco switch and an HP Procurve
http://www.youtube.com/watch?v=GdaGTVyQG38
487
