Getting SSH error 'connection refused'
sonikbaby
I need some help on this issue. On some routers and switches I am getting connection refused when trying to SSH to them. Telnet works fine ofcourse. I am  thinking it maybe the 'crypto key generate rsa' command is missing? But some of the routers that are having the issue have that command issued.  Here is the configuration (I removed encrypted passwords)  What could it be?
ALAM-RTR1-2811#show run
Building configuration...
version 12.4
service password-encryption
hostname ALAM-RTR1-2811
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no logging console
enable secret 5
aaa new-model
aaa authentication login default group radius local-case
aaa accounting exec default start-stop group radius
aaa accounting network default start-stop group radius
aaa session-id common
resource policy
memory-size iomem 10
clock timezone MDT -7
clock summer-time mdt recurring
ip subnet-zero
ip cef
no ip domain lookup
ip domain name parametrix.com
ip ssh rsa keypair-name ALAM-RTR1-2811
ip ssh version 2
modemcap entry usrmodem1:MSC=&FS0=1&C1&D3&H1&R2&B1
username routeradmin secret 5
interface Loopback1
ip address 172.30.127.254 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
interface FastEthernet0/0
description Uplink to Quest MPLS
no ip address
duplex full
speed 100
interface FastEthernet0/0.705
description Quest qmoe
encapsulation dot1Q 705
ip address 192.168.252.65 255.255.255.192
no snmp trap link-status
interface FastEthernet0/0.706
description Quest MPLS
encapsulation dot1Q 706
ip address X.x.X.x 255.255.255.252
interface FastEthernet0/1
description Uplink to internal network
ip address 172.30.0.1 255.255.252.0
duplex full
speed 100
ip classless
ip route 0.0.0.0 0.0.0.0 63.234.101.209
ip route x.x.x.x 255.255.255.252 x.x.x.x.
ip route 172.21.0.0 255.255.128.0 192.168.252.66
ip route 172.22.0.0 255.255.128.0 x.x.x.x.x
ip route 172.30.0.0 255.255.128.0 172.30.0.30
ip http server
no ip http secure-server
snmp-server community XXXXXX RW 1
snmp-server community XXXXXX RO 1
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps envmon
snmp-server enable traps config
radius-server host 172.24.10.44 auth-port xxxx acct-port xxxx key 7
control-plane
banner exec ^CCC
Welcome to the Parametrix Albuquerque Router
^C
banner login ^CCC Welcome to the Albuquerque Router .  Please login.
^C
banner motd ^CCC
        >>>>>>>>>> WARNING <<<<<<<<<<
Unauthorized access to this system is a violation of the Federal Electronics
Communications Privacy  Act of 1986, and may result in fines of $250,000
and/or imprisonment (Title 18, USC).
^C
line con 0
exec-timeout 30 0
password 7 XXXXXXXXXXXXX
logging synchronous
line aux 0
logging synchronous
modem InOut
modem autoconfigure type usrmodem1
transport input all
autoselect during-login
autoselect ppp
flowcontrol hardware
line vty 0 4
exec-timeout 30 0
password 7 XXXXXXXXXXXXXXX
transport input telnet ssh
transport output all
scheduler allocate 20000 1000
ntp clock-period 17180099
ntp master 2
ntp server 140.142.16.34
end
17 Replies 17
Reza Sharifi
What is the IOS name and version for the devices that are not working?
Can you post "sh ver | inc bin"?
it is:
System image file is "flash:c2800nm-ipbasek9-mz.124-3g.bin"
The image looks good.
1-Did you create the crypto key?
2-If yes, can you replace
with
transport input all
and test again?
here is a link on how to generate the key
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml
Make sure you have console access to the router before making any changes for line vty 0 4
Ok thanks. I will try your suggestion and let you know how it goes.
Dear I need your help.
I have a Cisco Catalyst 4500. Which from one day to the next did not allow me to remotely connect via SSH from my PC. I had to start connecting from a test server. But after a while I can't connect from this server either.
I accessed the switch through an Access-List and both my PC and the server are still in it.
I compare the current running-config with one from a few months ago when I could access it without problems and there are no differences.
I attach the switch configuration
ip ssh logging events
ip ssh version 2
crypto pki trustpoint TP-self-signed-13161
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-13161
revocation-check none
rsakeypair TP-self-signed-13161
crypto pki profile enrollment 4500
crypto pki certificate chain TP-self-signed-13161
certificate self-signed 01 nvram:IOS-Self-Sig#3131.cer
power redundancy-mode redundant
port-channel load-balance dst-ip
ip access-list standard Management-Admin
permit 10.73.6.101 log
permit 10.73.2.55 log
permit 10.73.10.205 log (My PC)
permit 10.73.10.204 log
permit 10.73.2.250 log (Test Server)
permit 172.17.7.82 log
permit 0.0.0.208 255.255.255.0
permit 10.73.102.0 0.0.0.255 log
permit 10.73.10.0 0.0.0.255 log
control-plane
line con 0
password 7 1214041E021E5D557C
logging synchronous
stopbits 1
line vty 0 4
access-class Management-Admin in
exec-timeout 0 0
timeout login response 300
privilege level 15
password 7 03347B5E5318715E4A434854414B
transport input ssh
transport output ssh
line vty 5
exec-timeout 0 0
privilege level 15
transport input ssh
transport output none
Leo Laohoo
One of the reason is this.  And where's your crypto?
ntp master 2
Get rid of this line.
isn't the no ip http secure-server just disabling HTTP management? How is that related to ssh?
  Thats correct that just shuts off the secure GUI function .  Check keys, show crypto key my rsa .    You can also try zeroizing the key and recreating it .
I ended up re-creating my crypto key to fix the issue. The problem is I don't know why it needed to be recreated as ssh worked before.
Thank you msenko, I had the same problem.  I even generated new keys and it still did not work.  I then zeroized them and re-created them, and it worked.
The problem occurred after a reboot of the router.  Prior to reboot it worked fine.
The version I am using is 15.4(3)S on ASR1006.  Maybe its a bug.
Glad to have helped pledge500, thanks for your response!
inside (Config)#
ip ssh port <network_port> rotary 1
rotary 1
Don't forget these commands
Hello @sonikbaby, Hello all,
Is it possible to pin the crypto key regeneration answer to the top and mark this question as answered ?
In order to ease future searches.
AhmadmKefaya
Hi there,
i had the same issue today after i upgraded my router, i checked "show ip ssh" and i saw the version "SSH Enabled - version 1.99", i tried to SSH from my Putty but it was giving this error on the router logging:
%SSH-3-NO_MATCH: No matching mac found: client hmac-sha1,hm ac-sha1-96,hmac-md5 server hmac-sha2-256,hmac-sha2-512
this error mean your Putty ( or the client that you using to ssh to the Router) is sending SSH version 1.0 and you your router is supporting 1.99 as minimum ssh version, what i noticed that my Putty was old version 0.60 i updated to the latest then its start working.
Hope that will help.
Ahmad Kefaya
