GGSN Configuration - Not responding pdp-Context request
Hi all,
Kindly help me.
My GGSN is not responding to PDP-Context request.
Here is my configuration.
aaa new-model
aaa acc
ounting suppress null-username
aaa accounting update periodic 5
aaa accounting network vmuk start-stop group radius
aaa pod server auth-type any server-key mysecret
aaa session-id common
clock timezone GMT 0
ip cef
ip name-server x.x.x.x
interface GigabitEthernet0/0
no ip address
interface GigabitEthernet0/0.172
description ### GRX User Space ###
encapsulation dot1Q 172
ip address x.x.x.x. x.x.x.x
interface GigabitEthernet0/0.569
description ### GRX Space  ###
encapsulation dot1Q xxx
ip address x.x.x.x x.x.x.x
interface Virtual-Template1
ip unnumbered GigabitEthernet0/0.xxx
encapsulation gtp
gprs access-point-list gprs
no ip http server
  access-point 1
   access-point-name mobile.barablu.com
   ip-address-pool dhcp-proxy-client
   aggregate auto
   dhcp-server x.x.x.x y.y.y.y
   dhcp-gateway-address x.x.x.x
   network-request-activation
   dns primary x.x.x.x secondar y y.y.y.y
gprs mcc xxx mnc xxx
gprs gtp echo-timer dynamic enable
gprs gtp n3-requests 8
gprs gtp ip udp ignore checksum
gprs default ip-address-pool dhcp-proxy-client
gprs qos map canonical-qos
gprs qos default-response requested
radius-server host x.x.x.xauth-port 1645 acct-port 1646 non-standard key 7 xxxxxxxxxxxxxxxxxxxxx
radius-server key 7 xxxxxxxxxxxxxxxxxxxxxx
radius-server vsa send accounting
and here is debug log
Dec  3 20:03:04.489: GPRS:proc_udp_input: signalling packet from X.X.X.X(2123)
Dec  3 20:03:04.489: GPRS:gtp_mgmt_process: wakes up
Dec  3 20:03:04.489: GPRS:major 2 minor 2;
Dec  3 20:03:04.489: GPRS:gtp_mgmt_process_qinput: GTPv1C_MSG
Dec  3 20:03:04.489: GPRS:sequence num 0xF571
Dec  3 20:03:04.489: GPRS:gtpv1_ggsnmsg_create_pdp_context_req: TEID 00 from X.X.X.X
Dec  3 20:03:04.489: GPRS:Found PDP Context
Dec  3 20:03:04.489: GTP IE:extract_teid: return teid 0xE8AA3414
Dec  3 20:03:04.489: GPRS:apn_lookup:apn TEST.COM
Dec  3 20:03:04.489: GPRS: found apn TEST.COM
Dec  3 20:03:04.489: GPRS:pdpmcb_create_by_teid:teid 0x0000001F, pdpmcb 2356587C
Dec  3 20:03:04.489: GPRS:pdp_create_by_tid:tid 3204011040029159, pdp 235558C0
Dec  3 20:03:04.489: GTP IE:3204011040029159:IMSI[2]:3204011040029109
Dec  3 20:03:04.489: GTP IE:3204011040029159:Recover[14]:142
Dec  3 20:03:04.489: GTP IE:3204011040029159:Selection Mode[15]:0
Dec  3 20:03:04.489:        MS or network provided APN, subscribed verified
Dec  3 20:03:04.489: GTP IE:3204011040029159:TEID Data1[16]:0x235558F8
Dec  3 20:03:04.489: GTP IE:3204011040029159:TEID Control[17]:0x235558F0
Dec  3 20:03:04.489: GTP IE:3204011040029159:NSAPI[20]:5
Dec  3 20:03:04.489: GTP IE:3204011040029159:Charging Characteristics[26]:0x8
Dec  3 20:03:04.489: GTP IE:3204011040029159:APN[131]:TEST.COM
Dec  3 20:03:04.489: GTP IE:3204011040029159:PCO[132](PAP):
Dec  3 20:03:04.489: GTP IE:3204011040029159:PCO[132](IPCP primary DNS addr):0.0.0.0
Dec  3 20:03:04.489: GTP IE:3204011040029159:PCO[132](IPCP secondary DNS addr):0.0.0.0
Dec  3 20:03:04.489: GTP IE:3204011040029159:GSN Addr[133](sig):X.X.X.X
Dec  3 20:03:04.489: GTP IE:3204011040029159:GSN Addr[133](data):149.254.198.75
Dec  3 20:03:04.489: GTP IE:3204011040029159:MSISDN[134]:447574370984
Dec  3 20:03:04.489: GTP IE:3204011040029159:QoS[135]:value incorrect
Dec  3 20:03:04.489: GTP IE:3204011040029159:QoS[135]:len 13 incorrect
Dec  3 20:03:04.489: GTP IE:3204011040029159:Mandatory IE invalid 135 flag:0x10000002
Dec   3 20:03:04.489: %GTP-2-PDPACTIVATIONFAIL: GTP PDP activation/update  failed, GSN: 0.0.0.0, TID: 00, Reason: Mandatory info element invalid
Dec  3 20:03:04.489: GPRS:3204011040029159:gtp_msg_send_res: pdp_entry 0x235558C0, replymsg 0x11, cause 0xC9
Dec  3 20:03:04.489: %GTP-0-GTPv1PACKETPARSINGERROR: GSN: Y.Y.Y.Y, TEID: E8AA3414, APN: NULL, Reason: Mandatory ie incorrect
Dec  3 20:03:04.489: GPRS:GTP enqueues pak of size 16 (refcount 1)
Dec  3 20:03:04.489: GPRS:gprs_output:idb 0x2244743C, pkt 0x22E51E0C, path 0x0, pdp 0x0
Dec  3 20:03:04.489: GPRS:ip=C005618, ip->prot=17
Dec  3 20:03:04.489: GPRS:path_lookup: path to (dst:port) (X.X.X.X:2123)
Dec  3 20:03:04.489: GPRS::src Y.Y.Y.Y,dst X.X.X.X,srcport 2123,dstport 2123
Dec  3 20:03:04.489: GPRS:: Calling ip_udp_send()
Dec  3 20:03:04.489: GPRS:3204011040029159:pdp_cleanup: refcnt 0, pdp 235558C0, apn 239FC8D0, path 0, data_path 0
Dec  3 20:03:04.489: GPRS:3204011040029159:stop_msgtimer: PDP context 235558C0 timer 23555960
Dec  3 20:03:04.489: GPRS:3204011040029159:msgtimer is already off, pdp 235558C0
Dec  3 20:03:04.489: GPRS:3204011040029159:stop_purgetimer:pdp 235558C0
Dec  3 20:03:04.489: GPRS:radix_free: freeup PDP 235558C0
Dec  3 20:03:04.489: GPRS:pdpmcb_cleanup: refcnt 0, pdpmcb 2356587C, apn 239FC8D0
Dec  3 20:03:04.489: GPRS:gtp_apn_pdpmcb_unlink_one: list_remove() error
Dec  3 20:03:04.489: GPRS:gtp_mgmt_process_qinput: msg(17) processed
Dec  3 20:03:04.489: GPRS:gtp_mgmt_process: sleep
1 REPLY
Hi All,
I have managed to found the issue. And have fixed it already. It was IOS compatibality issue.
753
