07-13-2014 05:58 PM - edited 03-07-2019 08:02 PM
Hi.. Anybody experience an error in gigabit copper transceiver? We have 2 4500x switch that is configured in VSS. in each switch we have 16ports 1gbe copper module, we want to test HA of the device so we restart 1 4500x switch but when it boots up, there are ports that didn't power up and every time we reboot the same switch, there are random ports that won't power up but when we manually change the transceiver of the other ports, it will power up. there's also no error when we check the logs. Asking for any help. I'm really not sure if its a transceiver problem. thanks
Solved! Go to Solution.
07-13-2014 10:52 PM
Could you try XE version 3.5.3E and see if there are improvements?
07-13-2014 07:53 PM
Sounds like a bug.
What IOS version and what kind of transceivers?
07-13-2014 08:02 PM
Hi Leo thanks for your reply, IOS-XE software version is 03.05.00.E. The transceiver that we used is 1gbe copper SFP transceiver.
07-13-2014 10:52 PM
07-14-2014 09:26 PM
Ok. I will try to upgrade the IOS. will get back to you as soon as possible. thanks
