Gigabit NICs
Hi. Recently, we've upgraded to Gigabit switches. Has anyone seen workstation 'slowness' stem from this upgrade and it NOT be a speed/duplex mismatch thing.... perhaps a NIC card incompatibility. We seem to have this mostly with 3560s... Thoughts?
Green
Re: Gigabit NICs
Are you trying to use Jumbo frames? Are all the devices set for the proper MTU?
Have you checked you cabling? Improper or poorly terminated cabling can cause these symptoms (try kicking the Nic down to 10/half ... if throughput gets better, you have crap cables).
Check it out and let us know
Scott
Re: Gigabit NICs
Thanks Scott. We will be trying this on the weekend and we'll surely let you know.
129
