03-22-2008 11:56 AM - edited 03-05-2019 09:54 PM
Here's the configuration:
interface GigabitEthernet1/23
description test
switchport
switchport access vlan 140
switchport mode access
switchport nonegotiate
speed 1000
duplex full
no cdp enable
spanning-tree portfast
The cable is straight and in good condition. I noticed when I inserted the cable to this port, the LED lid on that specific port turn to OFF. As checked the interface status, its down / down. I tried to shut and no shut but I got the same result.
Is there any way to check the integrity of that specific port? Thanks.
03-23-2008 04:41 PM
Depending on the module(s) you have installed and the IOS version you're running, you can try this link:
http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SXF/configuration/guide/intrface.html#wp1066783
Steve
03-23-2008 11:17 PM
hi
did u try checking up the logs ?
if not do check up when you are trying this.
That mite provide some clue on the possible reason behind this behavior.
regds
