GLBP config
We have once L2 switch dually homed to two 2800 routers, we are running HSRP on both routers. To load balance traffic between the two routers we tried to move to GLBP, but once we remove HSRP and configure GLBP we see no traffic at all passing to the routers. Here's the GLBP config we added
Router 1 (Active router)
track 10 interface serial 0/0/0 line-protocol
track 20 interface serial 0/1/1 line-protocol
int g0/0
glbp 2 ip 10.1.70.6
glbp 2 load-balancing weighted
glbp 2 preempt
glbp 2 weighting 110 lower 95 upper 105
glbp 2 weighting track 10
glbp 2 weighting track 20
glbp 2 priority 105
Router 2
track 10 interface serial 0/0 line-protocol
track 20 interface serial 0/1 line-protocol
int e0/0
glbp 2 ip 10.1.70.6
Re: GLBP config
Some show commands..
Router1
Router1#sh glbp brie
Interface Grp Fwd Pri State Address Active router Standby route
Gi0/0 2 - 105 Active 10.1.70.6 local 10.1.70.5
Gi0/0 2 1 7 Active 0007.b400.0201 local -
Gi0/0 2 2 7 Listen 0007.b400.0202 10.1.70.5 -
Router1#sh glbp
GigabitEthernet0/0 - Group 2
State is Active
2 state changes, last state change 00:17:21
Virtual IP address is 10.1.70.6
Hello time 3 sec, hold time 10 sec
Next hello sent in 2.564 secs
Redirect time 600 sec, forwarder time-out 14400 sec
Preemption enabled, min delay 0 sec
Active is local
Standby is 10.1.70.5, priority 100 (expires in 8.500 sec)
Priority 105 (configured)
Weighting 110 (configured 110), thresholds: lower 95, upper 105
Track object 10 state Up decrement 10
Track object 20 state Up decrement 10
Load balancing: weighted
Group members:
0005.5e8e.f160 (10.1.70.5)
0016.4610.6bd8 (10.1.70.4) local
There are 2 forwarders (1 active)
Forwarder 1
State is Active
1 state change, last state change 00:17:11
MAC address is 0007.b400.0201 (default)
Owner ID is 0016.4610.6bd8
Redirection enabled
Preemption enabled, min delay 30 sec
Active is local, weighting 110
Forwarder 2
State is Listen
MAC address is 0007.b400.0202 (learnt)
Owner ID is 0005.5e8e.f160
Redirection enabled, 598.500 sec remaining (maximum 600 sec)
Time to live: 14398.500 sec (maximum 14400 sec)
Active is 10.1.70.5 (primary), weighting 110 (expires in 8.500 sec)
Router1#sh glbp active
State is Active
2 state changes, last state change 00:17:30
Next hello sent in 2.672 secs
Active is local
Standby is 10.1.70.5, priority 100 (expires in 8.612 sec)
Group members:
Forwarder 1
State is Active
1 state change, last state change 00:17:20
Redirection enabled
Forwarder 2
State is Listen
Redirection enabled, 598.612 sec remaining (maximum 600 sec)
Time to live: 14398.612 sec (maximum 14400 sec)
Active is 10.1.70.5 (primary), weighting 110 (expires in 8.612 sec)
Re: GLBP config
More show commands
Router 2
Router2#sh glbp brie
Interface Grp Fwd Pri State Address Active router Standby router
Et0/0 2 - 100 Standby 10.1.70.6 10.1.70.4 local
Et0/0 2 1 - Listen 0007.b400.0201 10.1.70.4 -
Et0/0 2 2 - Active 0007.b400.0202 local -
Router2#sh glbp
State is Standby
1 state change, last state change 00:15:37
Next hello sent in 2.135 secs
Preemption disabled
Active is 10.1.70.4, priority 105 (expires in 7.159 sec)
Standby is local
Priority 100 (default)
Forwarder 1
State is Listen
MAC address is 0007.b400.0201 (learnt)
Time to live: 14397.151 sec (maximum 14400 sec)
Active is 10.1.70.4 (primary), weighting 110 (expires in 7.147 sec)
Forwarder 2
State is Active
1 state change, last state change 00:15:44
MAC address is 0007.b400.0202 (default)
Router2#sh glbp active
Router2#
Super Bronze
Re: GLBP config
GLBP uses a different virtual MAC then HSRP. Likely clients where still trying to get to the gateway IP address using the prior HSRP MAC. You'll need to flush the client ARP caches after making the switch.
Re: GLBP config
did u ever get this problem sorted??
if yes what was the issue???
can u pls post it so that it can help us
197
