Webcast-Catalyst9k
GLBP keep failing over
Have anybody seen GLBP on 6509 LAN router keep failling over back and forward? Below is the sample from router log.
Jan 23 04:56:09 UTC: %GLBP-6-STATECHANGE: GigabitEthernet4/8 Grp 7 state Standby -> Active
Jan 23 04:56:09 UTC: %GLBP-6-FWDSTATECHANGE: GigabitEthernet4/8 Grp 7 Fwd 2 state Listen -> Active
Jan 23 04:56:09 UTC: %GLBP-6-STATECHANGE: GigabitEthernet4/8 Grp 7 state Active -> Speak
Jan 23 04:56:09 UTC: %GLBP-6-FWDSTATECHANGE: GigabitEthernet4/8 Grp 7 Fwd 2 state Active -> Listen
Re: GLBP keep failing over
according to cisco.com's error message decoder (which is a great troubleshooting tool by the way):
%GLBP-6-STATECHANGE: [chars] Grp [int] state [chars] -> [chars]
The GLBP gateway has changed state.
Recommended Action: No action is required.
Related documents- No specific documents apply to this error message.
in other words, it's an informational syslog. your glbp's working smooth.
Bronze
Is this device the Active Virtual Gateway(AVG) or one of the Active Virtual Forwarders(AVF). The state change is probably coming from another device which is flapping. I would check the other devices in the group. Do a show glbp and look for which state the device is in (State is Active) and look for the line which reads (Active is local) this should tell you the AVG of the group.
1364
