Webcast-Catalyst9k
GLBP Not Load-Balancing Properly?
I having configured GLBP and using Host-dependent as a load-balancing algorithem. But all the traffice is passing through one rtr only.
For your reference i have attached my topology diagram.
There are two L3 Switches running HSRP for each vlan interface. For half of the vlans, L3-SW-1 is active and for rest L3-SW-2 is active. and pc's are assigned the respective vlan's vip. These L3's are connected to a 3500 L2 Switch which also connects the Core rtrs. which are running glbp.
RTR-A is configured as AVG. I am having a default route in Both L3's to point the traffic to GLBP VIP 10.9.0.1
But all the traffice is passing via RTR-A and both the are learning the VMAC of RTR-A only. I tried clearing the arp-cache but they learn the same VMAC.
I also tried changing the AVG to RTR-B but still no results. Configrations are as follows-
RTR-A# interface FastEthernet0/4
ip address 10.9.0.74 255.255.255.0
glbp 1 ip 10.9.0.1
glbp 1 priority 120
glbp 1 preempt
glbp 1 weighting 110
glbp 1 load-balancing host-dependent
glbp 1 forwarder preempt delay minimum 10
RTR-B# interface FastEthernet0/4
ip address 10.9.0.75 255.255.255.0
glbp 1 ip 10.9.0.1
glbp 1 preempt
L3-SW-1#int vlan1
ip add 10.9.0.2 255.255.255.0
standby 1 ip 10.9.0.3
standby 1 priority 150
standby 1 preempt
int vlan2
ip add 10.10.0.2 255.255.255.0
standby 2 ip 10.10.0.3
standby 2 preempt
L3-SW-2#
int vlan1
ip add 10.9.0.4 255.255.255.0
standby 1 preempt
int vlan2
ip add 10.10.0.4 255.255.255.0
standby 2 priority 120
standby 2 preempt
Any suggetions apprecited?
Thanks in Advance.
Pankaj
344
