GLBP on two 877s
I have to 877 routers and I am trying to create a failove and load balancing scenario. They are connected through a HP procurve 1824 switch. When I am getting a lot of errors on the standby routers to do with not being able to find the virtual interface with the IP of the active router. Any help would be gratefully recieved.
Please find example of config bellow
interface Vlan1
ip address 1.0.0.4 255.255.255.0
ip nat inside
ip virtual-reassembly
glbp 1 ip 1.0.0.1
glbp 1 ip 1.0.0.2 secondary
glbp 1 timers 5 18
glbp 1 timers redirect 600 7200
glbp 1 priority 250
glbp 1 preempt delay minimum 60
glbp 1 weighting 250
glbp 1 load-balancing weighted
glbp 1 authentication text some words
glbp 1 name example
glbp 1 weighting track 1 decrement 249
and the show glbp on the bad router
Vlan1 - Group 1
State is Standby
7 state changes, last state change 00:12:49
Virtual IP address is 1.0.0.1
Secondary virtual IP address 1.0.0.2
Hello time 5 sec, hold time 18 sec
Next hello sent in 0.084 secs
Redirect time 600 sec, forwarder time-out 7200 sec
Authentication text "text"
Preemption enabled, min delay 60 sec
Active is 1.0.0.4, priority 250 (expires in 15.072 sec)
Standby is local
Priority 200 (configured)
Weighting 200 (configured 200), thresholds: lower 1, upper 200
Track object 1 state Up decrement 199
Load balancing: weighted
IP redundancy name is "example"
Group members:
0014.f2ce.7f46 (1.0.0.3) local
001c.b1ec.11b2 (1.0.0.4)
There are 2 forwarders (1 active)
Forwarder 1
State is Listen
4 state changes, last state change 00:13:37
MAC address is 0007.b400.0101 (learnt)
Owner ID is 001c.b1ec.11b2
Time to live: 7195.080 sec (maximum 7200 sec)
Preemption enabled, min delay 30 sec
Active is 1.0.0.4 (primary), weighting 250 (expires in 13.080 sec)
Arp replies sent: 3
Forwarder 2
State is Active
1 state change, last state change 02:32:40
MAC address is 0007.b400.0102 (default)
Owner ID is 0014.f2ce.7f46
Active is local, weighting 200
Arp replies sent: 2
Thanks in advance
1 REPLY
Re: GLBP on two 877s
Sorry I feel I should clarify the problem appears to be that when traffic is sent to the main router it is fine but then no traffic can go to the interface and you cannot ping the interface. I think this is when it is forwarding to the secondary.
Debug errors gives
*Apr 4 22:24:41.011: GLBP: Vl1 API ARP active virtual address 1.0.0.5 not foun
d
for a variety of ip's in the range
144
