GLBP traffic
hello all,
I have successfully configured GLBP on my network but i have some doubts. how can i verify that traffic is actually being balanced on both outbound links? another thing is...i have one 60meg link and one 15meg link, how can i make more traffic go out the link with 60meg?
Everyone's tags (1)
VIP Super Bronze
GLBP traffic
If you want traffic to go out the 60mb link, then you raise the priority of AVG on the router that connects to your 60mb link.
Here is good doc to refer to on how to do it:
http://blog.ine.com/2008/04/24/glbp-explained/
GLBP traffic
Hi Reza,
thanks for the link. it is very helpful. I think there is a twist to my config. I have BGP running on both routers as well and i have set some local pref on the routers, meaning, even if i am GLBP'ing i am not actually using one link right? isn't that what the local pref config does? check out below;
#sh glbp
GigabitEthernet0/1 - Group 1
  State is Active
    1 state change, last state change 02:27:31
  Virtual IP address is 192.168.1.1
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 2.692 secs
  Redirect time 600 sec, forwarder time-out 14400 sec
  Preemption enabled, min delay 0 sec
  Active is local
  Standby is 192.168.1.3, priority 100 (expires in 7.636 sec)
  Priority 150 (configured)
  Weighting 100 (default 100), thresholds: lower 1, upper 100
  Load balancing: round-robin
  Group members:
    0023.5e29.9401 (192.168.1.2) local
    5057.a856.c281 (192.168.1.3)
  There are 2 forwarders (1 active)
  Forwarder 1
    State is Active
      1 state change, last state change 02:26:56
    MAC address is 0007.b400.0101 (default)
    Owner ID is 0023.5e29.9401
    Redirection enabled
    Preemption enabled, min delay 30 sec
    Active is local, weighting 100
  Forwarder 2
    State is Listen
    MAC address is 0007.b400.0102 (learnt)
    Owner ID is 5057.a856.c281
    Redirection enabled, 597.680 sec remaining (maximum 600 sec)
    Time to live: 14397.508 sec (maximum 14400 sec)
    Active is 192.168.1.2 (primary), weighting 100 (expires in 9.888 sec)
R1
router bgp 100
no synchronization
bgp router-id 44.20.14.2
bgp default local-preference 200
R2
router bgp 100
bgp log-neighbor-changes
bgp default local-preference 150
189
