11-06-2014 12:12 AM - edited 03-07-2019 09:24 PM
Hello everyone
We have 2 Internet routers configured with GLBP as well as with GLBP weighting but according to our traffic analyzer software the traffic is not distributed properly
Router 1:
interface GigabitEthernet0/1.30
bandwidth 10000000
encapsulation dot1Q 30
ip address X.X.X.222 255.255.255.0
ip access-group ip-egressnew in
ip nbar protocol-discovery
ip flow ingress
ip nat outside
ip virtual-reassembly in
glbp 30 ip X.X.X.2
glbp 30 priority 110
glbp 30 preempt
glbp 30 weighting 45
glbp 30 load-balancing weighted
glbp 30 name vlan30
service-policy output TO-SWT
Router 2:
bandwidth 10000000
ip address X.X.X.223 255.255.255.0
ip flow ingress
ip flow egress
ip nat outside
glbp 30 ip X.X.X.2
glbp 30 priority 105
glbp 30 preempt
glbp 30 weighting 55
glbp 30 name vlan30
As you can see, we have distributed the weighting in proportion of 44/55 but the in reality the traffic is distributed 10Mbs/140Mb/s
What can be the problem?
Thank you!
Solved! Go to Solution.
11-06-2014 07:24 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Hmm, well GLBP weighting is how it distributes gateways between its clients, it doesn't account for actual client load usage. I.e. it's possible one (or some) host(s) is sending lots and lots of traffic which would skew your load balancing. (Also, I recall same client will always map to same gateway [assuming no other changes].)
11-06-2014 07:24 AM
Disclaimer
Posting
11-06-2014 11:36 PM
Dear Joseph, Thank you for you reply
Indeed, we have 2 or 3 Internet Servers, that consumes the majority of traffic. Is it possible that these servers always get one gateway?
The load changes from time to time between Router A and Router B, it can be, for exaple, 10/140 and in 3 or 4 hours, 140/10
Is there any option I can distribute it more evenly?
11-07-2014 03:32 AM
Disclaimer
Posting
With only two or three servers, I would expect wild swings because flows are not balanced, but source hosts are. So, again, if one of those servers is especially active, compared to the others, your load balancing will be uneven.
What you might do is look into load balancing products, but if you're working with gig interfaces, how really important is load balancing them? I.e. is the busy gateway holding back or dropping ingress traffic? (Even if all your traffic is on just one gateway, if that's only about 150 Mbps, that shouldn't be much of an issue on a gig interface.)
11-07-2014 03:37 AM
Yes, we are using gig interfaces, was just wondering if there is any technique to achieve a real load balancing with glbp
Thank you anyway!
