GLC-FE-100FX SFP cause 3750 series switch port in to errordisable state
Dear Experts,
We have Catalyst 3750 Series Switches. All are connected with Single mode fiber cable. But at some of the places yet Multimode fiber cable is there. So we need SFP compatible to 3750 switch.
We had GLC-FE-100FX SFP which is perfectly working on 2960 series switch but on 3750 series switch as I inserted in module the port gose in to error disable state and giving the following error :
%PM-4-ERR_DISABLE: gbic-invalid error detected on Gi2/0/28, putting Gi2/0/28 in err-disable state
Now how can I connect 100BASEFX capable device running on Multimode Fiber cable with 3750 series switches.
Pls help soon.
Deepesh P.
1 ACCEPTED SOLUTION
Re: GLC-FE-100FX SFP cause 3750 series switch port in to errordi
This transceiver is not compatible with 3750, see page 112 of this excellent document (u can see some other options).
Sam
Hall of Fame Super Silver
Hello Deepesh,
see table 7 in the following compatibility matrix
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL632702.html
you need a minimum version of 12.2(20)SE to support it on the C3750
Hope to help
Giuseppe
Giuseppe,
Am I missing something here ?
On table 7 I cannot see that 3750 support GLC-FE-100FX (it does support GLC-GE-100FX on IOS u quoted)
Sam
Hello Sam,
you're right thanks for your correction.
I've misread the table.
Best Regards
Giuseppe
Bronze
Sam,
You're right. The Cat3xxx switches supports GLC-GE-100FX.
GLC-FE-100FX are for Cat6500 and others like it.
Cisco has unfortunately created quite a compatibility mess in the FastEthernet fibre SFP area, so we all have to keep our tongue in cheek, when we order SFP's.
Btw, Sam, you mention a document in your first response, but I do not see a link for that document.
HTH.
1806
