GNS 3 iosvl2 Switch not Forwarding DHCP reply packets to the requesting vlan
Naix
I'm new to networking and GNS3 so please correct me if I'm wrong.
All Switches are CISCO IOSvL2 appliances
I'm trying to get DHCP requests across vlans, my DHCP resides of VLAN 2 IT whilst the client computers reside on vlan 3 Clients which are trying to request DHCP access
 It seems That the DHCP Server Discover packets are reaching the DHCP-Server however the Reply that the DHCP server sends is not forwarded from the SW-IT to SW-Main
Attached is the Packets intercepted from the DHCP-server to the SW-IT then  SW-Main
Configuration Dumps
For the sake of troubleshooting I'll dump all my configs here
Main Router Config Dump
MainRouter-1#sh run
Building configuration...
Current configuration : 953 bytes
version 15.2
hostname MainRouter-1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
interface FastEthernet0/0
 no ip address
 duplex full
interface FastEthernet0/0.2
 encapsulation dot1Q 2
 ip address 192.168.2.1 255.255.255.0
 ip helper-address 192.168.2.2
interface FastEthernet0/0.3
 encapsulation dot1Q 3
 ip address 192.168.3.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
SW-Main Configuration Dump
SW-Main>en
SW-Main#sh run
Current configuration : 3693 bytes
! Last configuration change at 13:54:30 UTC Sun Jun 10 2018
version 15.2
service compress-config
hostname SW-Main
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/0
 switchport mode trunk
 media-type rj45
 negotiation auto
interface GigabitEthernet0/1
 media-type rj45
 negotiation auto
interface GigabitEthernet0/2
 media-type rj45
 negotiation auto
interface GigabitEthernet0/3
 media-type rj45
 negotiation auto
interface GigabitEthernet1/0
 media-type rj45
 negotiation auto
interface GigabitEthernet1/1
 media-type rj45
 negotiation auto
interface GigabitEthernet1/2
 media-type rj45
 negotiation auto
interface GigabitEthernet1/3
 media-type rj45
 negotiation auto
interface GigabitEthernet2/0
 media-type rj45
 negotiation auto
interface GigabitEthernet2/1
 media-type rj45
 negotiation auto
interface GigabitEthernet2/2
 media-type rj45
 negotiation auto
interface GigabitEthernet2/3
 media-type rj45
 negotiation auto
interface GigabitEthernet3/0
 media-type rj45
 negotiation auto
interface GigabitEthernet3/1
 media-type rj45
 negotiation auto
interface GigabitEthernet3/2
 media-type rj45
 negotiation auto
interface GigabitEthernet3/3
 media-type rj45
 negotiation auto
no ip http server
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS  *
* education. IOSv is provided as-is and is not supported by Cisco's      *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any       *
* purposes is expressly prohibited except as otherwise authorized by     *
* Cisco in writing.                                                      *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
 login
end
SW-Main VLAN table Dump
SW-Main#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Gi0/3, Gi1/0, Gi1/1, Gi1/2
                                                Gi1/3, Gi2/0, Gi2/1, Gi2/2
                                                Gi2/3, Gi3/0, Gi3/1, Gi3/2
                                                Gi3/3
2    IT                               active
3    Clients                          active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
2    enet  100002     1500  -      -      -        -    -        0      0
3    enet  100003     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
SW-Main trunk Configuration
SW-Main#sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi0/0       on               802.1q         trunking      1
Gi0/1       on               802.1q         trunking      1
Gi0/2       on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi0/0       1-4094
Gi0/1       1-4094
Gi0/2       1-4094
Port        Vlans allowed and active in management domain
Gi0/0       1-3
Gi0/1       1-3
Gi0/2       1-3
Port        Vlans in spanning tree forwarding state and not pruned
Gi0/0       1-3
Gi0/1       1-3
Gi0/2       1-3
SW-IT Config Dump
SW-IT#sh run
Current configuration : 3695 bytes
! Last configuration change at 13:54:27 UTC Sun Jun 10 2018
version 15.2
hostname SW-IT
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 media-type rj45
 negotiation auto
 switchport access vlan 2
 switchport mode access
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
no ip http server
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
 login
end
SW-IT Vlan table dump
SW-IT#sh vlan
1    default                          active    Gi1/0, Gi1/1, Gi1/2, Gi1/3
                                                Gi2/0, Gi2/1, Gi2/2, Gi2/3
                                                Gi3/0, Gi3/1, Gi3/2, Gi3/3
2    IT                               active    Gi0/1, Gi0/2, Gi0/3
3    Clients                          active
1003 tr    101003     1500  -      -      -        -    srb      0      0
Remote SPAN VLANs
SW-IT Trunk Configuration dump
SW-IT#sh int trunk
Gi0/0       auto             n-802.1q       trunking      1
Gi0/0       1-4094
Gi0/0       1-3
Gi0/0       1-3
SW-Clients Configuration Dump
SW-Clients#sh run
Current configuration : 3613 bytes
! Last configuration change at 13:54:32 UTC Sun Jun 10 2018
version 15.2
hostname SW-Clients
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 media-type rj45
 negotiation auto
 switchport access vlan 3
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
no ip http server
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
 login
end
SW-Clients#
SW-Clients Vlan Table dump
SW-Clients#sh vlan
                                                Gi3/3
2    IT                               active
3    Clients                          active    Gi0/1, Gi0/2
Remote SPAN VLANs
SW-Clients Trunk Configuration dump
SW-Clients#sh int trunk
Gi0/0       1-4094
Gi0/0       1-3
Gi0/0       1-3
SW-Clients#
DHCP-Server Configuration Dump
DHCP-Server#sh run
Current configuration : 1000 bytes
version 15.2
hostname DHCP-Server
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp excluded-address 192.168.2.0 192.168.2.10
ip dhcp excluded-address 192.168.3.0 192.168.3.10
ip dhcp pool IT
 network 192.168.2.0 255.255.255.0
 default-router 192.168.2.1
ip dhcp pool Clients
 network 192.168.3.0 255.255.255.0
 default-router 192.168.3.1
no ip domain lookup
no ipv6 cef
 ip address 192.168.2.2 255.255.255.0
 duplex full
no ip http server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
What I'am i doing wrong
Thanks For assisting me
2 Accepted Solutions
on your main and IT router, either configure a static route:
MainRouter-1
ip route 0.0.0.0 0.0.0.0 192.168.2.2
DHCP-Server
ip route 0.0.0.0 0.0.0.0 192.168.2.1
or configure a routing protocol:
MainRouter-1
router eigrp 1
network 0.0.0.0
no auto-summary
DHCP-Server
router eigrp 1
network 0.0.0.0
no auto-summary
on the main router, change the vlan 2 subinterface back to what it was (no native):
Also, make sure that the switchport connected to your DHCP-Server router is configured as an access port in vlan 2.
You need to be able to reach 192.168.3.1 from the DHCP server.
20 Replies 20
DenisfromBE
I'm not sure but I would say that it's because DHCP-Server doesn't know where the DHCP discovery packets come from (192.168.3.x)
It does not has the route to reply back.
Is there any way I can route the DHCP replys back to the requester ?
If you don't want to use routing protocol then a static default route on DHCP-Server toward f0/0 or the next-hop IP should be fine. But DHCP-Server must know where to send the packets back from 192.168.3.x
assuming that you can ping 192.168.2.2 from your MainRouter, the problem might simply be that portfast is not configured on your clients switchports. Add the line below to your port configs:
media-type rj45
negotiation auto
spanning-tree portfast
I've added spanning-tree portfast to my configs on SW-Clients, the VPCs on vlan 3 still couldn't reach the DHCP server
SW-Clients Config dump
SW-Clients#sh run
Current configuration : 3811 bytes
! Last configuration change at 03:10:49 UTC Sat Jun 23 2018
version 15.2
hostname SW-Clients
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 spanning-tree portfast edge
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
no ip http server
control-plane
on your Main_Router, tag Vlan 2 as native:
encapsulation dot1Q 2 native
Do I leave spanning-tree portfast on the switches or do i remove that configuration before entering this ?
leave that on there...
After entering that command
encapsulation dot1q 2 native
my router cannot ping the DHCP server.
Is this normal ?
Update: The Clients on SW-Clients Still cannot reach the DHCP server
hang on, I have this set up in GNS3, I'll check...
MainRouter-1
DHCP-Server
MainRouter-1
router eigrp 1
network 0.0.0.0
no auto-summary
DHCP-Server
router eigrp 1
network 0.0.0.0
no auto-summary
Do I keep the two previous Configurations
yes, just add either the static routes or the EIGRP. You need to be able to reach 192.168.2.2 from your main router...
Did it function on your end @Georg Pauwen ? because on my end there is still no ping between the
DHCP-server and the Main-Router.
