mx
goofed up a 2948g
I got a no longer used 2948G from work and I went to console into it, but cant seem to configure it. Once I can get to an enable prompt Im a whiz at setting up a switch but if it doesnt get there, sadly I get kind of lost. Heres what the screen says:
0:00.576665: Please set IPAddr variable
0:00.577246: Please set Netmask variable
0:00.577602: Please set Broadcast variable
0:00.577967: No gateway has been specified
0:00.578459: Network is not configured
WS-C2948G bootrom version 6.1(4), built on 2001.07.30 14:43:26
H/W Revisions: Fin: 2 Head: 11 Board: 1
Supervisor MAC addresses: 00:08:7c:e5:fc:00 through 00:08:7c:e5:ff:ff (1024 addresses)
Installed memory: 64 MB
Testing LEDs.... done!
rommon 1 >
Hmmm ok now what?!?!? I have maintenance so no problems getting the image for it if need be.
Thanks for any tips.
bob
mx
Re: goofed up a 2948g
Ahh after a little bit of digging in the help and a little bit of brain scanning from my ccna days I rememebered:
rommon 6 > set boot config-register 0x2102
rommon 7 > reset
0:00.576618: Please set IPAddr variable
0:00.577199: Please set Netmask variable
0:00.577558: Please set Broadcast variable
0:00.577925: No gateway has been specified
0:00.578416: Network is not configured
The system will autoboot in 5 seconds.
Type control-C to prevent autobooting.
rommon 1 >
The system will now begin autobooting.
Autobooting image: "bootflash:cat4000.5-5-10.bin"
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC##############################
Starting Off-line Diagnostics
Mapping in TempFs
Board type is WS-X2948
DiagBootMode value is "post"
Telling ApkPageMan that we have 12288 pages of memory
Loading diagnostics...
Power-on-self-test for Module 1: WS-X2948
Status: (. = Pass, F = Fail)
processor: . cpu sdram: . rtc: .
eprom: . nvram: . flash: .
temperature sensor: . enet console port: . switch registers: .
switch sram: .
Module 1 Passed
Power-on-self-test for Module 2: WS-C2948G
Port status: (. = Pass, F = Fail)
1: . 2: . 3: . 4: . 5: . 6: . 7: . 8: .
9: . 10: . 11: . 12: . 13: . 14: . 15: . 16: .
17: . 18: . 19: . 20: . 21: . 22: . 23: . 24: .
25: . 26: . 27: . 28: . 29: . 30: . 31: . 32: .
33: . 34: . 35: . 36: . 37: . 38: . 39: . 40: .
41: . 42: . 43: . 44: . 45: . 46: . 47: . 48: .
49: . 50: .
Module 2 Passed
Exiting Off-line Diagnostics
bad log
IP address for Catalyst not configured
DHCP/BOOTP will commence after the ports are online
Ports are coming online ...
Cisco Systems, Inc. Console
Enter password:
2006 Nov 11 16:27:56 %SYS-4-NVLOG:convertCiscoMIB:PreSac(0) checksum failed: 0x0(0x4C5C)
2006 Nov 11 16:27:56 %SYS-4-NVLOG:supVersion:Nmp version 5.5(10)
2006 Nov 11 16:27:57 %SYS-5-MOD_OK:Module 1 is online
2006 Nov 11 16:28:05 %SYS-5-MOD_OK:Module 2 is online
Console>
Of course I have no idea what the password is so thats yet another chapter. Hope this helps someone.
thanks
Silver
Hi ,
try out the following commands.
Console> sho boot
BOOT variable =
Configuration register is 0x0
ignore-config disabled
console baud 9600
boot the ROM monitor
> - dir bootflash
Console> dir bootflash
-#- -length- -----date/time------ name
1 2842972 Jan 01 2000 000241 cat4000.4-5-9.bin
8691236 bytes available (2843100 bytes used)
and then ""set boot config-register boot bootflashcat4000.4-5-9.bin""
checkout the below for Successive Power Cycling During a Boot Leaves the Switch in ROMMON
http://www.cisco.com/warp/public/770/fn12396.shtml
Password Recovery Procedure for the Catalyst 1200, 1400, 2901, 2902, 2926T/F, 2926GS/L, 2948G, 2980G, 4000, 5000, 5500, 6000, 6500 Running CatOS
http://www.cisco.com/warp/public/474/pswdrec_6000.html
Hope it helps you.
satish
Purple
The first thing to try is just issue the command "boot bootflash:" . If there is an image in bootflash it should load it . Not sure if you can do a "dir bootflash: at the rommon prompt but you might be able to to see if the image is in bootflash and it just did not boot due to a incorrect boot statement.
830
