08-24-2007 06:02 AM - edited 03-05-2019 06:05 PM
Hello all,
When issuing the sh log command, it usually gives me logs from june to present. It takes quite some time to go through them to reach the latest logs.
Is there a method or command which allows me to display the logs for just today or for the past week...
Solved! Go to Solution.
08-24-2007 06:19 AM
Dan
I believe that you may get pretty close to what you are looking for with the "show log | include" feature. The pipe include gives you the ability to match a character string. So if you were to enter
show log | include Aug 24
then it would show only records in the log that have Aug 24 in the log record. This presumes that you have configued your syslog to use timestamp datetime.
Rick
08-24-2007 06:19 AM
Dan
Rick
08-24-2007 06:31 AM
yes that worked great, thanks.
08-24-2007 06:37 AM
Dan
I am glad that my suggestion helped you. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read an answer that resolved the question. I encourage you to continue your participation in the forum.
Rick
