GRE issue
boban-petrovic
The probelm is following: there is IP connectivity between public IP addresses, x.y.148.202 and x.y.132.202, but not between 10.0.10.1 and 10.0.10.2. Relevant configurations are following:
Router A:
interface Tunnel0
ip address 10.0.10.1 255.255.255.0
tunnel source Vlan1
tunnel destination x.y.132.202
interface Vlan1
ip address x.y.148.202 255.255.255.252
#sh ip int tu0
Tunnel0 is up, line protocol is up
  Internet address is 10.0.10.1/24
  Broadcast address is 255.255.255.255
  Address determined by setup command
  MTU is 1476 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Multicast reserved groups joined: 224.0.0.5
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF Feature Fast switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is disabled
  BGP Policy Mapping is disabled
#sh int tu0
  Hardware is Tunnel
  MTU 1514 bytes, BW 9 Kbit, DLY 500000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source x.y.148.202 (Vlan1), destination x.y.132.202
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255
  Fast tunneling enabled
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
Router B:
interface Tunnel0
ip address 10.0.10.2 255.255.255.0
tunnel source GigabitEthernet0/0
tunnel destination x.y.148.202
interface GigabitEthernet0/0
description outside
ip address x.y.132.202 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
#sh ip int tu0
  Internet address is 10.0.10.2/24
  MTU is 1476 bytes
  IP CEF switching turbo vector
  IP Null turbo vector
  Input features: MCI Check
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
#sh int tu0
  Hardware is Tunnel
  MTU 17916 bytes, BW 100 Kbit/sec, DLY 50000 usec,
  Keepalive not set
  Tunnel source x.y.132.202 (GigabitEthernet0/0), destination x.y.148.202
   Tunnel Subblocks:
      src-track:
         Tunnel0 source tracking subblock associated with GigabitEthernet0/0
          Set of tunnels with source GigabitEthernet0/0, 1 member (includes iterators), on interface <OK>
  Tunnel TTL 255, Fast tunneling enabled
  Tunnel transport MTU 1476 bytes
I believe that there is some problem with MTUs, but I'm not so sure. How to correct this configuration?
Dan Frey
Hi Boban,
The OSPF config on Router A could be an issue.   The redistribute connected command also includes the WAN interface IP.   Would recommend adding a routemap filter so the WAN IP is not included in the OSPF advertisement.
Is the redistribute static command needed on this router, I only see a default static route?
- Dan
21 Replies 21
Peter Paluch
Boban,
Even if you ping the 10.0.10.2 from the router having the IP address 10.0.10.1 or vice versa, is the ping unsuccessful? Such ping is deep below the MTU. If the ping is unsuccessful, your problem is most probably caused by something different than MTU.
Is there any firewall en route between these two routers that could potentially drop GRE traffic? Are you using any ACLs or firewall mechanisms on these routers?
Best regards,
Peter
Peter,
Thanks for the answer.
The ping is unsuccessful.
There are a couple of ACLs, but for other purposes (OSPF, NAT,..) and neither of them is applied to vlan1 or gi0/0 explicitly.
Both routers are connected to WAN via vlan1 and gi0/0 interfaces to the same ISP, I don't believe that ISPdo not allow gre.
On router B, there is NAT configured. Can that make some problems in this case?
Hello Boban,
Without knowing your entire configuration, it is difficult to say. Would it be possible to post the entire configuration of both your routers, with the sensitive information removed?
Best regards,
Peter
Router A:
#sh run
version 12.4
logging buffered 8192 debugging
no logging console
no logging monitor
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
interface Tunnel0
ip ospf cost 200
tunnel source Vlan1
interface FastEthernet0/0
ip address 192.168.0.17 255.255.255.252
ip ospf network non-broadcast
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.0.3 255.255.255.240
duplex auto
speed auto
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Vlan1
router ospf 10
log-adjacency-changes
redistribute connected metric-type 1 subnets
redistribute static metric-type 1 subnets
network 10.0.10.0 0.0.0.255 area 0
network 192.168.0.0 0.0.255.255 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 x.y.148.201
no ip http server
access-list 1 permit 192.168.0.0 0.0.255.255
control-plane
line con 0
line aux 0
line vty 0 4
access-class 1 in
exec-timeout 120 0
login local
transport input all
transport output all
end
Router B:
version 15.1
service password-encryption
hostname routerb
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no ipv6 cef
ip source-route
ip cef
login block-for 100 attempts 10 within 60
redundancy
ip ssh version 2
interface Loopback0
no ip address
interface Tunnel0
ip ospf cost 200
interface Embedded-Service-Engine0/0
no ip address
shutdown
description outside
ip address x.x.132.202 255.255.255.252
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1.2
description Management
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/1.3
description LAN
encapsulation dot1Q 3
ip address 192.168.3.1 255.255.255.0
ip nat inside
router ospf 1
router-id 192.168.2.1
redistribute connected subnets route-map control-ospf
network 192.168.0.0 0.0.255.255 area 0.0.0.0
network 10.0.10.0 0.0.0.255 area 0.0.0.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool nat-pool x.y.132.202 x.y.132.202 prefix-length 30
ip nat inside source list nat-allowed pool nat-pool overload
ip route 0.0.0.0 0.0.0.0 x.y.132.201
ip access-list standard nat-allowed
permit 192.168.3.0 0.0.0.255
ip access-list standard ospf-allowed
permit 10.0.10.0 0.0.0.255
access-list 23 permit 192.168.0.0 0.0.0.255
route-map control-ospf permit 10
match ip address ospf-allowed
snmp-server community secret RO 23
control-plane
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
login local
transport input ssh
transport output telnet ssh
scheduler allocate 20000 1000
end
Hi Boban,
I do not see any obvious configuration error here. The NAT should not be a problem but still, for testing purposes, you should temporarily deactivate it, remove all NAT entries from the NAT table using the clear ip nat translation command and try the ping again.
It would also be helpful to try to turn on tunnel debugging using the command debug tunnel and seeing if the tunneled packets are being properly sent from either device - and whether they are received at all on the other device. This output may provide us with some clues as to what is happening.
Best regards,
Peter
Peter,
I turne on debug tunnel on router A, and then tried to ping 10.0.10.2. Here is part of output of sh logging:
*Dec 28 23:19:20.320: Tunnel0: GRE/IP encapsulated x.y.148.202->x.y.132.202 (linktype=7, len=124)
*Dec 28 23:19:22.320: Tunnel0: GRE/IP encapsulated x.y.148.202->x.y.132.202 (linktype=7, len=124)
*Dec 28 23:19:24.320: Tunnel0: GRE/IP encapsulated x.y.148.202->x.y.132.202 (linktype=7, len=124)
*Dec 28 23:19:26.320: Tunnel0: GRE/IP encapsulated x.y.148.202->x.y.132.202 (linktype=7, len=124)
*Dec 28 23:19:30.112: Tunnel0: GRE/IP encapsulated x.y.148.202->x.y.132.202 (linktype=7, len=100)
*Dec 28 23:19:40.112: Tunnel0: GRE/IP encapsulated x.y.148.202->x.y.132.202 (linktype=7, len=100)
*Dec 28 23:19:50.112: Tunnel0: GRE/IP encapsulated x.y.148.202->x.y.132.202 (linktype=7, len=100)
*Dec 28 23:20:00.112: Tunnel0: GRE/IP encapsulated x.y.148.202->x.y.132.202 (linktype=7, len=100)
*Dec 28 23:20:10.112: Tunnel0: GRE/IP encapsulated x.y.148.202->x.y.132.202 (linktype=7, len=100)
*Dec 28 23:20:20.112: Tunnel0: GRE/IP encapsulated x.y.148.202->x.y.132.202 (linktype=7, len=100)
I can see ping with 2 seconds delays, and keepalive packets probably with 10 secs delays after that, but I haven't configured keepalive, and thats strange.
When I do the same on Router B, I can see similiar output.
Dec 28 23:15:17.331: Tunnel0: GRE/IP to classify x.y.148.202->x.y.132.202 (tbl=0,"Default" len=100 ttl=250 tos=0x0)
Dec 28 23:15:17.331: Tunnel0: GRE/IP (PS) to decaps x.y.148.202->x.y.132.202 (tbl=0,"default" len=100 ttl=250)
Dec 28 23:15:17.331: Tunnel0: GRE decapsulated IP packet (linktype=7, len=76)
Dec 28 23:15:27.331: Tunnel0: GRE/IP to classify x.y.148.202->x.y.132.202 (tbl=0,"Default" len=100 ttl=250 tos=0x0)
Dec 28 23:15:27.331: Tunnel0: GRE/IP (PS) to decaps x.254.148.202->x.y.132.202 (tbl=0,"default" len=100 ttl=250)
Dec 28 23:15:27.331: Tunnel0: GRE decapsulated IP packet (linktype=7, len=76)
Dec 28 23:15:37.331: Tunnel0: GRE/IP to classify x.y.148.202->x.y.132.202 (tbl=0,"Default" len=100 ttl=250 tos=0x0)
Dec 28 23:15:37.331: Tunnel0: GRE/IP (PS) to decaps x.y.148.202->x.y.132.202 (tbl=0,"default" len=100 ttl=250)
Dec 28 23:15:37.331: Tunnel0: GRE decapsulated IP packet (linktype=7, len=76)
Dec 28 23:15:47.327: Tunnel0: GRE/IP to classify x.y.148.202->x.y.132.202 (tbl=0,"Default" len=100 ttl=250 tos=0x0)
Dec 28 23:15:47.327: Tunnel0: GRE/IP (PS) to decaps x.y.148.202->x.y.132.202 (tbl=0,"default" len=100 ttl=250)
Dec 28 23:15:47.327: Tunnel0: GRE decapsulated IP packet (linktype=7, len=76)
And this is when I try to ping 10.0.10.1:
Dec 28 23:19:20.783: Tunnel0: GRE/IP encapsulated x.y.132.202->x.y.148.202 (linktype=7, len=124)
Dec 28 23:19:20.783: Tunnel0 count tx, adding 0 encap bytes
Dec 28 23:19:22.783: Tunnel0: GRE/IP encapsulated x.y.132.202->x.y.148.202 (linktype=7, len=124)
Dec 28 23:19:22.783: Tunnel0 count tx, adding 0 encap bytes
Dec 28 23:19:24.783: Tunnel0: GRE/IP encapsulated x.y.132.202->x.y.148.202 (linktype=7, len=124)
Dec 28 23:19:24.783: Tunnel0 count tx, adding 0 encap bytes
Dec 28 23:19:26.783: Tunnel0: GRE/IP encapsulated x.y.132.202->x.y.148.202 (linktype=7, len=124)
Dec 28 23:19:26.783: Tunnel0 count tx, adding 0 encap bytes
Dec 28 23:19:28.783: Tunnel0: GRE/IP encapsulated x.y.132.202->x.y.148.202 (linktype=7, len=124)
Dec 28 23:19:28.783: Tunnel0 count tx, adding 0 encap bytes
adding 0 encap bytes looks strange, hmmmm...
I can't deactivate NAT because this routers are in production environment.
And this is the output on router B when I ping 10.0.10.2 from router A:
Dec 28 23:30:29.647: Tunnel0: GRE/IP to classify x.y.148.202->x.y.132.202 (tbl=0,"Default" len=124 ttl=250 tos=0x0)
Dec 28 23:30:29.647: Tunnel0: GRE/IP (PS) to decaps x.y.148.202->x.y.132.202 (tbl=0,"default" len=124 ttl=250)
Dec 28 23:30:29.647: Tunnel0: GRE decapsulated IP packet (linktype=7, len=100)
Dec 28 23:30:29.647: Tunnel0: GRE/IP encapsulated x.y.132.202->x.y.148.202 (linktype=7, len=124)
Dec 28 23:30:29.647: Tunnel0 count tx, adding 0 encap bytes
Dec 28 23:30:31.643: Tunnel0: GRE/IP to classify x.y.148.202->x.y.132.202 (tbl=0,"Default" len=124 ttl=250 tos=0x0)
Dec 28 23:30:31.643: Tunnel0: GRE/IP (PS) to decaps x.y.148.202->x.y.132.202 (tbl=0,"default" len=124 ttl=250)
Dec 28 23:30:31.643: Tunnel0: GRE decapsulated IP packet (linktype=7, len=100)
Dec 28 23:30:31.643: Tunnel0: GRE/IP encapsulated x.y.132.202->x.y.148.202 (linktype=7, len=124)
Dec 28 23:30:31.643: Tunnel0 count tx, adding 0 encap bytes
Dec 28 23:30:33.643: Tunnel0: GRE/IP to classify x.y.148.202->x.y.132.202 (tbl=0,"Default" len=124 ttl=250 tos=0x0)
Dec 28 23:30:33.643: Tunnel0: GRE/IP (PS) to decaps x.y.148.202->x.y.132.202 (tbl=0,"default" len=124 ttl=250)
Dec 28 23:30:33.643: Tunnel0: GRE decapsulated IP packet (linktype=7, len=100)
Dec 28 23:30:33.643: Tunnel0: GRE/IP encapsulated x.y.132.202->x.y.148.202 (linktype=7, len=124)
Dec 28 23:30:33.643: Tunnel0 count tx, adding 0 encap bytes
Dec 28 23:30:35.643: Tunnel0: GRE/IP to classify x.y.148.202->x.y.132.202 (tbl=0,"Default" len=124 ttl=250 tos=0x0)
Dec 28 23:30:35.643: Tunnel0: GRE/IP (PS) to decaps x.y.148.202->x.y.132.202 (tbl=0,"default" len=124 ttl=250)
Dec 28 23:30:35.643: Tunnel0: GRE decapsulated IP packet (linktype=7, len=100)
Dec 28 23:30:35.643: Tunnel0: GRE/IP encapsulated x.y.132.202->x.y.148.202 (linktype=7, len=124)
Dec 28 23:30:35.643: Tunnel0 count tx, adding 0 encap bytes
Dec 28 23:30:37.643: Tunnel0: GRE/IP to classify x.y.148.202->x.y.132.202 (tbl=0,"Default" len=124 ttl=250 tos=0x0)
Dec 28 23:30:37.643: Tunnel0: GRE/IP (PS) to decaps x.y.148.202->x.y.132.202 (tbl=0,"default" len=124 ttl=250)
Dec 28 23:30:37.643: Tunnel0: GRE decapsulated IP packet (linktype=7, len=100)
Dec 28 23:30:37.643: Tunnel0: GRE/IP encapsulated x.y.132.202->x.y.148.202 (linktype=7, len=124)
Dec 28 23:30:37.643: Tunnel0 count tx, adding 0 encap bytes
So we can see that router B receives pings via tunnel and decapsulate them. After that, Router B encapsulate ping replies, but add 0 encap bytes. Now, I will check what is happening with ping replies on router A.
Hi Boban,
The GRE packets sent in 10-second intervals are most probably OSPF Hello packets, as you have OSPF running over the tunnel. Most probably, these are not keepalives.
The information about adding 0 encapsulation bytes is strange indeed.
Let's make another experiment. On Router B, activate these debugs:
debug tunnel
debug ip icmp
Then, from Router A, ping Router B and capture the debug output.
Best regards,
Peter
this is the output:
Dec 28 23:45:39.303: Tunnel0: GRE/IP to classify x.y.148.202->x.y.132.202 (tbl=0,"Default" len=124 ttl=250 tos=0x0)
Dec 28 23:45:39.303: Tunnel0: GRE/IP (PS) to decaps x.y.148.202->x.y.132.202 (tbl=0,"default" len=124 ttl=250)
Dec 28 23:45:39.303: Tunnel0: GRE decapsulated IP packet (linktype=7, len=100)
Dec 28 23:45:39.303: ICMP: echo reply sent, src 10.0.10.2, dst 10.0.10.1, topology BASE, dscp 0 topoid 0
Dec 28 23:45:39.303: Tunnel0: GRE/IP encapsulated x.y.132.202->x.y.148.202 (linktype=7, len=124)
Dec 28 23:45:39.303: Tunnel0 count tx, adding 0 encap bytes
Dec 28 23:45:41.303: Tunnel0: GRE/IP to classify x.y.148.202->x.y.132.202 (tbl=0,"Default" len=124 ttl=250 tos=0x0)
Dec 28 23:45:41.303: Tunnel0: GRE/IP (PS) to decaps x.y.148.202->x.y.132.202 (tbl=0,"default" len=124 ttl=250)
Dec 28 23:45:41.303: Tunnel0: GRE decapsulated IP packet (linktype=7, len=100)
Dec 28 23:45:41.303: ICMP: echo reply sent, src 10.0.10.2, dst 10.0.10.1, topology BASE, dscp 0 topoid 0
Dec 28 23:45:41.303: Tunnel0: GRE/IP encapsulated x.y.132.202->x.y.148.202 (linktype=7, len=124)
Dec 28 23:45:41.303: Tunnel0 count tx, adding 0 encap bytes
Router B successfuly receives ping reply and tries to answer it. It encapsulates ping response, but Router A never receives that response. I think that adding 0 encap bytes is the key problem.
boban-petrovic
I've added network 10.0.10.0 0.0.0.255 area 0 to OSPF proces on router B, and router A become the OSPF neighbour to router B, but in INIT state, which shows that tunnel is functionig good in A->B direction, but not otherwise.
Boban,
Thank you for all your investigation. I agree with your assessment of the situation: that the B->A direction is not working. The "0 encap bytes" seems to be rather suspicious to me. However, I see no direct way of solving this problem. This seems to me to be an IOS bug.
One possibility to try is to delete and recreate the Tunnel interface on Router B, possibly using a different tunnel interface number (i.e. not Tun0 but, e.g., Tun1).
Another possibility - potentially disruptive and dangerous - is to temporarily disable and reenable CEF. The CEF is heavily involved in the process of encapsulating the GRE-tunelled packets, and this procedure will erase and repopulate all CEF structures, supposing there may be a problematic entry. Alternatively, you may want to try to erase the CEF structures manually using two commands: clear cef table ipv4 and clear adjacency
Considering the fact that this behavior is obviously erroneous, I would also suggest reloading the device and/or changing the IOS version (by the way, what is the exact IOS version on Router A and B?). Obviously, this needs to be done in a maintenance window.
Best regards,
Peter
Peter,
Thanks for your answers.
I've tried to delete Tunnel 0 and then create Tunnel 1, but problem persisted.
I'll try to reload the router B, when working conditions allow it.
Router B:
#sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M2, RELEASE SOFTWARE (fc1)
Router A:
#sh ver
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(3i), RELEASE SOFTWARE (fc2)
Message was edited by: Boban Petrovic; Router B is 15.1, and router A is 12.4
Boban,
Thank you for the info. Regarding the IOS version on the router B, it is strongly outdated and I would personally strongly vouch for upgrading it, along with the reload.
Best regards,
Peter
EDIT: The 12.4(3i) is outdated The 15.1 IOS is one of the current IOSes but obviously buggy. I would also consider upgrading it to a newer 15.1M release if possible.
Dan Frey
Hi Boban,
- Dan
